Results 1 to 9 of 9
Thread: anyone use a normal atx powersupply on their car?
    Jan 2005
    Richmond, VA
    Does anyone use a normal atx psu in their car hooked via an inverter. I'm planning on installing a carputer in my car and I'm looking for the cheapest solution possible. I have plenty of atx power supplies, has anyone made like a custom switch or something that tells the computer to hibernate or shutdown when the car turns off?
    FLAC evandude's Avatar
    Mar 2005
    Maine
    quick, put on your flame suit!
    here's a clue: on the list of all the forums, here's what it says for this one:
    Power Supplies (34 Viewing)
    Inverters, DC-DC, shutdown controllers, etc
    and in the FAQ emporium (always a good resource for such questions) you might have found the thread:
    FAQ: Power Supplies Explained (Part 1)
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by kasemodz
    Depend on your hardware, M2-ATX PSU is a better solution (and probably cheaper) than inverter. M2-ATX has built-in shutdown controller to automate startup and shutdown. If you go with inverter, you have to buy a stand alone SDC to automate startup/shutdown. Most of the SDC cost almost half what M2 cost.
    BTW, try to search for inverter to see why it is NOT a prefer method to power the PC in the car.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Nov 2005
    Sell all the ATX power supplies and get an opus or M2-ATX.
    1999 Lexus GS300- (going VIP)
    1993 Lexus SC300-Turbo (Totaled by idiot driver)
    1996 Lexus SC400- (Totaled by brother)
    1972 Datsun 240Z- (WIP)
    1994 Toyota Camry- (sold)
    Nov 2005
    Quote Originally Posted by MatrixPC
    And if your hardware needs more juice than what the M2-ATX can supply, there is always the DSATX. Or M2-ATX + auxiliary Opus POL(s).
    With an inverter you need to add in the cost of a SDC. And AC-DC supplies are inefficient compared to DC-DC.
    There are legitimate reasons to use an inverter in a carPC solution, however I do not really think cost is one of them - unless you planning to reuse an existing inverter setup.
    Jan 2005
    Richmond, VA
    Ok, well my system is going to be:
    Soyo k7vme Mobo
    Athlon Xp-m 1400+
    1 Gb Ram or 512Mb depending on usage
    1gb CF Card
    Possibly 60 gb 2.5in hard drive? (External perhaps)
    Slim Load Dvd Player
    I used other calculators and it said 200 watts total at peak. I find that pretty high, a normal k7 cpu, mobo should take about 110 watts. And I ahve a mobile cpu, so that should lower it more to about 100. In other words, the maximum wattage shouldn't go over 150 watts.
    Mar 2005
    Maine
    My home desktop computer is an athlon 64 3200+ with a power-hungry 3.5" SATA hard drive (that almost gets hot enough to burn you), high-end video card (which also sucks a lot of power, and gets really hot), and a few PCI cards like TV tuner, sound card, etc... and my system only has a 250 watt power supply in it.
    My carPC is a similar system (M7NCG mobo, athlon XP-M 2200+, 512mb ram, laptop HD) to what you're proposing and I've never noticed it getting more than slightly warmer than ambient during operation. I've never measured its power consumption, but using heat generated as an indicator, I know it uses SIGNIFICANTLY less. If your proposed system uses even half as much power as my desktop I'd be quite surprised... so I would be willing to guess that an M2-ATX or opus 150w could handle it.
    by the way, do you have the mobo/processor yet? have you tried them? I am interested in seeing how people like other micro-ATX boards with the mobile processors (particularly, how much of a headache it is to get the mobile processors running on boards with chipsets such as VIA, which don't have software multiplier and FSB control in the BIOS) because I'm a bit sick of having a mobo that doesn't support suspend-to-RAM (S3 standby)
    eegeek.net
    Jan 2005
    Richmond, VA
    One more problem, my mobo requires a 12v line as well as the atx line. I could just use one of the molex connectors and wire one up but has anyone done that? It should be fine but just wanted you all input.
    Jan 2005
    Richmond, VA
    oh this mobo surprisingly accepts mobile processors. I was quite surprised. I've been using this sytem for my linux server 24/7 in my stuffed up closet. It runs like a charm no problems. The mobo even identifies the right cpu on post (Athlon XP-M 1400+). I've tried it on my other msi mobo but I like this soyo mobo better, mini atx and very rock solid realibility.
    Maybe I just got lucky lol, this via chipset never gave me any problems on the cpu
    Btw, I can adjust the fsb and multiplier on the bios.
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  2. 250W Car ATX PSU
    By bazmangr in forum Power Supplies
    Last Post: 05-13-2005, 07:58 PM
  3. For Sale for all you aussies. Complete mp3 car pc
    By Holden__V8 in forum Classified Archive
    Last Post: 04-09-2005, 06:30 AM
  4. powering a VIA MII w/ a ATX powersupply
    By boostedGT-S in forum Power Supplies
    Last Post: 01-20-2005, 01:57 PM
  5. Replies: 12
    Last Post: 12-04-2001, 07:36 PM
