Results 1 to 8 of 8
Thread: M1-ATX not powering mb
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    My M1-ATX is not sending a pulse to my motherboard to power it up. It was working but then my hard drive die now it wont send a pulse. I have to install a switch onto my motherboard to power it up anyway to fix this.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    What MB are you using?
    What do you mean your HD died?
    Are you sure the drive failed and not the MB? (or other part)
    TruckinMP3
    Read the FAQ!
    Jun 2006
    Houston, TX
    I am using the mII12000 Yes i am sure the drive fail. I been a computer tech for 12 years. I can power my mb fine if i use a switch or jump it but the M1-Atx will not send a pulse to it to turn it on. It has to be manually done.
    I install a new 80g 2.5 hard drive also and install windows. work great when jumpstart but will not do its other function like turn it off after 2 hours and so. No pulse getting sent.
    Jun 2002
    Colorado
    That information was not included and changes the potential answers. Good to know you have the right information and know what it means.
    Send an email to the folks that made the PS. Describe the issue, see what they say.
    TruckinMP3
    Read the FAQ!
    Jun 2006
    Houston, TX
    Who make thos M1 anyway
    Jun 2002
    Colorado
    TruckinMP3
    Read the FAQ!
    Jun 2006
    Houston, TX
    Experience tech do get burn out man
    Jun 2002
    Colorado
    I hope they have a good answer for you.
    Let us know the results.
    I hear you, Been there, don that. Good luck with the PS!
    TruckinMP3
    Read the FAQ!
  1. AMD AM2 CPU Low Wattage
    By ACE in forum General Hardware Discussion
    Last Post: 06-11-2006, 04:13 PM
  2. Replies: 0
    Last Post: 12-08-2005, 10:41 PM
  3. Does m1 atx have to be connected to mb
    By Silver Wing in forum Power Supplies
    Last Post: 12-08-2005, 07:15 AM
  4. Micro Atx MB
    By eazyrog in forum General Hardware Discussion
    Last Post: 08-26-2005, 07:37 AM
  5. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 08:03 PM
