I'm pretty sure your logic is flawed, and that the problem lies with your alternator/battery, but I'll let one of the electrical gurus analyze this..
I would like to know i can power my 175 watt inverter with a M2-ATX.
I have a Compaq/HP Evo 2.4ghz PC that I have been powering with a 175 watt inverter. It has been working great accept for when the car idles low, like at a stop-light with the music loud and the lights and or AC on.
When this happens the puter shuts down until the RPM’s go above 3000.
Usually taking my foot off the brake will reboot the computer.
I was originally going to use the M2 to power the PC with DC to DC power but the connections on the EVO computer’s motherboard has a different power connector
The Evo has an original 145 max power supply and is a P4, but I didn’t see a connection for the P4 Power Rail.
So what im thinking now is sense the M2 that I have can operate at 6 volts and im sure my voltage doesn’t drop lower than that during idle (should check). Would it be possible to power the inverter with the M2?
I know ill get allot of tank circuit or second battery suggestions, but I would rather work with what I have if I can.
But ANY advice Would Be Great
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Originally Posted by tj!2k4
Im pretty sure i could purchase a high voltage alternator or yellow top battery that may solve the issue but i was just wonderin if i could make it work sense i alreadyt have the M2. I also was thinking that some of the feature in the M2 like the 5 min delay before shutdown could be usefull at short-stops (gas, store, ect.).
If I was you, I will try to work around using the M2 to power the Compaq. Why don't you go that route? Does the Evo has special PSU/connector like those in Dell?
You don't want to do Car power -> regulated DC - > Inverter -> AC-DC.
Another problem is that the M2 only has 8A ( I think) on the 12V rail which is about 100W.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Yeah, as matrixPC pointed out, it would not be a good idea because you would only be using the 12v output, which is a bit under 100W. Not to mention, a 175 watt inverter can supply 175W, but it will take more power to run it at full load than that because it's not 100% efficient. As a rough guess, if it's 85% efficient that means it would draw over 200W of power when it is supplying 175W output, and worse if the efficiency is lower than that. So you're probably looking at about DOUBLE the power on the 12v rail that the M2-ATX could supply.
There are dedicated, single-output +12v DC-DC power supplies out there, however I don't know of any that are larger than about 100W, so that is probably not a good solution either.
In my opinion, your best bet is to figure out the wiring of your computer so you can hook up the M2-ATX directly and eliminate the inverter.
If you aren't electrically inclined enough for that, then perhaps you should buy a better inverter that can deal with lower input voltage. I have a coleman powermate 400W inverter that can survive crank with the computer running, and I only paid about $25-30 for it. and if it can survive crank, it should certainly be able to keep running while the engine is running, even at low idle. It sounds like you are running a relatively power-hungry PC; with a 175W inverter, you may be pushing it close to its rated limit, which means it will be strained more when the battery voltage droops than it would be if it was only running at, say, 50% load. That's one possible advantage of using a larger inverter, such as 400W. Just make sure you search the forums for recommendations of brands/models, because some inverters handle low input voltage better than others ( you want to find one that can survive engine cranking, ideally )
One question about a POSSIBLE fix to your current problem: do you have GOOD power wiring to the inverter? Bad=existing wire in the dash, or a cigarette lighter plug... Good= a suitable-gauge power wire run directly from the battery, and a solid ground to the chassis close to the inverter.
If your power wiring to the inverter is poor, there will be extra voltage drop on them, which would cause the inverter to get a lower input voltage than the actual battery voltage, which could make it shut down when the battery voltage had only drooped a little bit. One check would be to measure the battery voltage with the car idling and see at what voltage the computer shuts down, and then repeat the process by measuring the voltage at the power terminals of the inverter, and see if the voltage is much lower. If it is, then you should check/improve your wiring.
But don't take it from me! here's a quote from a real, live newbie:
eegeek.netOriginally Posted by Viscouse
yes it does have the special PSU connector. im not sure how the dell connector is but it looks similar to the standard 4 prog power connector accept i believe its like 6 or 8 prongs. If thats how the dell is there similar.
Do you know of an adapter for this setup?
I purchased this off of ebay last week.
http://cgi.ebay.com/Aims-400-1200-Wa...QQcmdZViewItem
It should be here today but for some reason i think i may run into the same problem with that inverter. but maybe not
I'll let you know
With 10V minimum working voltage, it may or may not survive cranking, but I am sure it will survive at engine idle.Originally Posted by Lava
If this inverter still give you problem, you may have to check wiring and voltage at the inverter and battery while engine is idle.
I used a 400W Xantrex inverter before in the Supra and it survive engine cranking without any problem.
adding a ps in front of an inverter etc isnt going to do much for you(gonna do nothing but be wrong). if theres not enough power theres not enough power. plain and simple.
buy a nice sized cap(it stores energy), put your system after the cap.. then when you hit hard when your car is at idle(not putting alot of juice back in the system). it will drian the cap before your battery.
Matrix he did say at idle with the music loud. im guessing otherwise when hes moving the alternator can keep up.. its just when hes stopped. what else does your system consit of? im guessing amp and sub/s?
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
Originally Posted by yrean
I read up on capacitors being used in our CarPC's and most talk about how they drain so fast that it wont help for a longer period of time. At say a stop light were you might be there for a min or so. Yet some say that it did solve there issue. i dont want a cap unless its going to solve the issue, plus i dont have a big system, No Big Bass box, just Good aftermarket 6" components all the way around and a 10" JL audio free-air to replace the factory sub ( sound like its enclosed tho). Two audiobaun amps totaling about 600 watts and a crossover. 8" touchscreen indash
I tried the new inverter yesterday and it was just a waste of money. It worked but same issue all night. I dont think its more efficient than my 175 watt inverter plus it beeps when it turns off as were the 175 boots the PC as soon as I take my foot off the brake after a stop light. So the 175 watt inverter is going back in today.
Im actually at the end of my rope with the inverter thing. Im moving on to either find a way to idle up to about 2500-3000 RPM's or use a second battery. I have new Grounds all around the car the Big Three is fine.
Im leaning toward running to Walmart right after this post, grabbing a best Deep cycle jump-off they have, and wiring up a second battery. ANY suggestions about his setup before I head out would be great.
Should i stop By Radio Shack also?
Thanks for all Ya Help
