Results 1 to 10 of 12
Thread: carnetix P1900 Battery Drain
    Jul 2006
    Hi, I am hoping someone can help me out.
    Here's my setup:
    Aopen Pandora MiniPC (powered by primary output of CNX-P1900)
    Xenarc 700tsv (powered by secondary output of CNX-P1900)
    Dlink 7-port powered USB hub (powered by CNX-P5V)
    Attached to Dlink USB hub are:
    USGlobalSat BU-353
    Audigy 2 NX
    Bluetooth adapter
    Mini-Key USB Keyboard DGPN-570
    DLYON connected to the remote wire for the amp.
    The carputer goes on standby (s3-suspend to ram) just fine but drains all the battery. How do I set it up so that my battery isn't drained? These are my jumper settings for JP1. (1-2) the jumper is set to the 1 only. (3-4) 3 only. (5-6) both the 5 and 6 is covered by the jumper. (7-8) not used. (9-10) 9 only.
    thx
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    s3 is going to drain your battery.. electricity is drawn in order to keep ram alive. try hibernate..
    Jul 2006
    Quote Originally Posted by Nomader
    hibernate with S1? or hibernate with S3? Either way electricity is going to be drawn correct?
    I just bought a Optimal Yellow Top to replace my stock battery. Hopefully this works....
    Elsewhere
    Unless you let your car sit for extended periods of time without driving it (we're talking several days) or your battery doesn't take a charge well, standby doesn't draw enough power to fully drain the battery.
    The only power that's required to maintain standby is power to the mobo & RAM.
    Quote Originally Posted by jumper6888
    Hibernation requires no power draw to maintain the state, as it writes the contents of RAM to a file on the HDD.
    Standby does require power to maintain state, as it suspends to RAM. You cut power to RAM, you lose the state and do a cold boot next time.
    How about the Wiki?
    Registered User
    Like DP said the problem is probably your stock battery, I had the same setup without any power drain problems. My car sat at the airport for a week and started without any problems once I got back and that was with my POS stock battery, but putting that constant strain on a regular battery will defiantly shorten its lifespan.
    Jul 2006
    Quote Originally Posted by DarquePervert
    Sorry for not behing specific but this is my daily driver. Well use to be but since school is out I've only been driving it about 3 times a week.
    Just for future reference. To set up hibernation I will have to set the jumper for the JP1 P1900 to cover the pin 5 only (default) correct?
    Quote Originally Posted by Kalt
    Thanks, Kalt. I built my Carputer around your suggestions in the aopen review thread. Do you hibernate or do standby?
    Jul 2006
    Ok the new yellow top battery did the trick. Now to my next problem. The computer only goes into standby about half the time. The other times it just restarts when I start my car. Anyone knows why?
    Elsewhere
    No... This is defined in the OS. The PSU simply sends the signal to the motherboard. The OS determines how to handle the signal.
    How about the Wiki?
    Jul 2006
    besides under the power option in windows xp i will have to set the jumper on the p1900 correct?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    you dont have to set ANY jumpers for this to work
    the power supply sends a signal to the mobo, the OS determines then what happens, for instance a laptop, if you press the power button, you can get it to suspend to ram, hibernate, shut down, restart
    whatever you have it set to, is what the psu will make it do
    in simple terms, the psu just presses the mobo's power button, no jumpers control what the OS does
  1. Does M1 not prevent battery drain while PC is on?
    By uncrase in forum Power Supplies
    Last Post: 10-29-2005, 03:59 PM
  2. Carnetix p1900 and Travla c138 120watt?
    By john_draws in forum Power Supplies
    Last Post: 05-27-2005, 12:42 AM
  3. CarNetix P1900 - Advantages Of Plugginf In Screen
    By sux89 in forum Power Supplies
    Last Post: 05-16-2005, 08:39 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  5. Replies: 1
    Last Post: 02-06-2004, 04:44 PM
