Results 1 to 10 of 12
Thread: DC-DC PSU and Dell Optiplex gx520
    Newbie OmegaAvenger's Avatar
    Apr 2006
    Austin Texas
    Hi, If i rewire a DSATX power supply or some other similar dc-dc spu, will it power a dell optiplex gx520?
    edit: http://www.dell.com/downloads/global..._GX520_300.jpg
    Mine is the smallest one in this picture
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    well, the powersupply for that computer (from what i can find) is 220watts, so ur already pulling a lot, and thats for the computer itself, no screens or anything else
    so you'd either need the DSATX, or a couple of power supplies in there
    theoretically it should work, but hte power supply mobo connector looks ATX, so i dont know why you'd have to rewire?
    Apr 2006
    Austin Texas
    I'm not sue if i have to tbh. Some dells have what appear to be standard atx power supplys, but the wiring is NOT atx standard, afaik there isn't a list of models that are normal atx instead of dell atx. Only way to know is to try it i geuss. I also dont need much more than it requires. Theres not a whole lot that be done to expand it. I'm gonna add a low-profile pci video card, and thats about it. The screen and such will have thier own power supply and what not in the dash.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    then best thing to do is get out a multimeter and test all of the pins
    better safe than sorry :T
    Apr 2006
    Austin Texas
    Aye, I'll do that asap and post the results
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    It should work if you get all the wire correctly.
    And use the meter to check for all wires while the PC is on and when off as well. The only thing it wouldn't work is probably the power good signal.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Elsewhere
    The problem with some Dell motherboards is that the power connector is not made to the ATX standard. I don't know if yours is or is not.
    For those units, a Carnetix PSU (like the P1900) is likley to meet your needs.
    If your unit connects with a "power brick", read the rating on it, and we can tell you whether it will work or not.
    How about the Wiki?
    Apr 2006
    Austin Texas
    Mine does not use a brick, ill double check when i get home (im at work) but i believe it has a 20 or 24pin plug and the 4pin p4 connector.
    Elsewhere
    I suggest taking the safe route and determining the pinout of the Dell's PSU (and/or motherboard) and comparing it tot he pinout on a standard ATX PSU to make sure they jive.
    Dell has been known to use proprietary hardware that doesn't conform to any specification except their own.
    How about the Wiki?
    Newbie Fallen's Avatar
    Feb 2006
    Yes, dell and their annoying proprietary powersupplies. Had this problem with a dimension 8100 I wanted to convert into a CarPC. My solution: found a cheap, new motherboard on ebay.
    Good luck
  1. Replies: 0
    Last Post: 12-08-2005, 11:41 PM
  2. Is this Dell PSU standard or proprietary?
    By SMOKINV8 in forum Power Supplies
    Last Post: 11-20-2005, 11:25 AM
  3. Will the opus work with a dell?
    By themurph1018 in forum Power Supplies
    Last Post: 02-23-2003, 12:23 AM
  4. Dell PSU DC-DC?
    By Romanz48 in forum Power Supplies
    Last Post: 09-02-2002, 04:17 AM
  5. dell psu
    By backpack09 in forum Power Supplies
    Last Post: 08-03-2002, 06:08 AM
