http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
Australian mp3car Portal
mp3car related links Check them out / Add some
mp3car FAQ - RTFF
[########==]80% Assembling
-=Current Progress: Working Sproggy supply, building box.=-
Don't use resistors, the way they drop the voltage is by heat, you could easily make a 50 watt heater for your car if your not carefull.
Also it'll be difficult to obtain an accureate 3.3v reference as the PC will effectivly appear to be a "resistor" with an unknown value.
Try a voltage regulator if your not very hot on electronics(althought max current might be an issue), alternatively if your a bit mor confidence try a switch mode supply.
Now for the blatant plug,
Have a look at www.mp3mini.tk for more info on PSU.
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
