Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 61
Thread: M2-ATX Catches Fire is 1st 3 minutes!!!
  1. #11
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    bummer, this is crazy...
    TruckinMP3
    Read the FAQ!
  2. #12
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    That is nuts...mine fired right up (no pun intended) and has been rock solid since day 1. I bought mine from DigitalWW.
  3. #13
    Mar 2006
    Colorado, but Canadian!
    My M2 is very stable. Every now and then the power switch goofs up, but after a second, it gets better.
    I agree with the Bermuda theory...
    1.9in x 2.9in -- 47mm x 73mm
  4. #14
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'm glad mine has worked from the start.. i wouldnt know if it caught fire til the whole damn trunk went up in flames lol
    Live mp3Car Facebook Chat
  5. #15
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Sounds like if I ever buy an M2, I will be putting one of the half dozen long-abandoned mobos wasting space in my closet to use to "burn-in" (pun fully intended) the power supply for a day or two before I dare hook it up to anything I value...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  6. #16
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by evandude
    haahahahahha, I am sure you have a few socket A mobos to spare.
    Well, no need to sacrify a mobo to experience. Just hardwire to turn on the PSU to power serveral CD-ROMs to play music or whatever as a burn-in method.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #17
    Mar 2005
    Maine
    Quote Originally Posted by MatrixPC
    like you wouldn't believe
    well, for starters, running a CDROM (which would only use the 12v and 5v rails, and not be too much of a load) may not be a very thorough safety test. Plus, some of these mobos I value less than a CD-ROM drive, and in many cases would get a certain satisfaction in the event they did go up in smoke...
    me:"so mobo, you don't support S3 either? well then you can BURN! say hello to my little friend... the M2-ATX!"
    mobo:*sizzle*...*pop*
    eegeek.net
  8. #18
    Jun 2005
    Michigan
    Quote Originally Posted by sama
    hoenstly I've had a great experience with my m2 and ampie. I have 2 m2's in fact, the second powers the rest of the kit.
    you guys are just unlucky I guess, or you have bad magneto-static bermuda-influced weather holes in your rooms/cars
    Im glad you've had a good experience, but you shouldnt order a product and have to toss the dice as to whether or not yours is going to explode or not. I know this happens to every complex device on the market, but there just seem to be way too many exploding M2's with so few of them actually being sold...
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
  9. #19
    Apr 2001
    Portland OR
    Quote Originally Posted by rsd212
    Im ready to become a full-time anti-M2ATX advocate. The failure rate seems to be a little TOO high, and when I looked up datasheets on some of the converters, they were not rated for the amperage specified in the M2-ATX manual. Too bad I was stupid enough to buy the Ampie case, so Im stuck with the M1/2's....
    It's not the controllers that are the problem, it's the useage of the controllers and the use of the MOSFETs and the thermal design that appears to be the problem here. The DSATX uses a similar controller but utilizes much higher quality MOSFETs as well as using a Mosfet packages that has a much better (lower) thermal resistance from the junction to the ambient. Everybody knows the M1/M2 are the value products, and the DSATX is the high-end high-cost product however.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  10. #20
    Jul 2006
    Quote Originally Posted by zootjeff
    I don't see it as a value product now!
    Zootjeff, you seem to know about some of the problems, care to elaborate? Feel free to speak engineer, I am an EE.
    Thanks,
    Greg
  1. M2 ATX Amp turn on not working
    By CdRsKuLL in forum M2-ATX
    Last Post: 04-23-2010, 01:25 PM
  2. Replies: 3
    Last Post: 01-06-2008, 04:11 PM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  4. WTB m2 atx
    By ampy549 in forum Classified Archive
    Last Post: 05-21-2006, 02:44 PM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
