Results 1 to 6 of 6
Thread: PSU as 5V and 12V power supplier
    Constant Bitrate teo256's Avatar
    Mar 2006
    Fossombrone (PU), Italy
    Hi all, i'm going to install a Sound Blaster Audigy 2 ZS Video Editor in my car. It is an external USB audio card that need external power to swith on. On the Adapter (for 100/220 V) theese are the outputs:
    5 Vdc (4A)
    12 Vdc (2A)
    I don't want to use an inverter 12/220 in my car. So i have an idea: i could use a CarPc PSU (i have an unused MOREX) that have both 12V and 5V outputs (see attachment for details).
    Can be this a good idea? And what about the ampere?
    Thanks, teo256
    Software [|||||||||-]
    My Own RR Skin [|||-------]
    8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
    RoadRunner - Destinator 6 - Waiting for RRMobile
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    i dont like pdfs, so im not going to open it
    but a lot of people have done this, as to the amps, it depends what the power supply is capable of outputting, most can get about 8amps on the 12v line, (not so sure about the 5), but as long as the power supply can handle those amps on those lines, then by all means, splice into the lines
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    (and all power supplies have 12v and 5v, they probably wont be seperate, so on the morex power lines yellow = 12v, black = ground, red = 5v)
    for the 12v power, one black one yellow
    for 5v power, one black one red
    Mar 2006
    here you are shots from pdf:
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Remember, you have to feed the PSU with regulated 12V.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2006
    Quote Originally Posted by MatrixPC
    I know that, this is not a problem.
    I'd like to know if using 12V and 5V PSU's outputs, i can power the Sound Blaster....
  1. How to power 5V usb hub from 12v
    By spaceman in forum General Hardware Discussion
    Last Post: 03-15-2010, 10:14 AM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
