Results 1 to 2 of 2
Thread: M1-ATX doesn't like 5V slim DVD?
    Mar 2004
    I have a confirmed working (with regular home power supply) slim toshiba DVD drive.. for some reason it refuses to be identified when running on the M1-atx.. in fact the system will post, doesn't find the drive, and then gives a disk read error even though primary master HDD (which it's set to boot from) is still in place.
    M9000, usb gps, usb TS, 3.5 12v hdd, nothing else crazy.
    is my M1-ATX weak or is there a solution?
    Thank You /////ALPINE
    7" Lilli. GPSlim236. Streetdeck. Mappoint. M9000. M2ATX, XMDirect
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    using too much power? If everything you have is using the 5v then you might be pushing the limit
  1. Slim DVD & IDE to USB - DVD QLTY
    By ZimZimmer in forum Newbie
    Last Post: 01-19-2007, 06:37 PM
  2. Slim, slot load, DVD drive, where to get one??
    By JonEQuest in forum General Hardware Discussion
    Last Post: 06-23-2005, 02:58 PM
  3. Slim Dvd Drive Issue
    By gboy in forum General Hardware Discussion
    Last Post: 02-15-2005, 04:56 PM
  4. FS: 7" Lilliput w/ TS, iMac slim slot load DVD
    By sohr in forum Classified Archive
    Last Post: 08-15-2004, 11:35 PM
  5. ITPS and Slim DVD Power question
    By no1knows in forum Power Supplies
    Last Post: 05-03-2004, 05:25 PM
