10uh Inductors from RS components
Just quick question can the 10uH inductor from RS be used insted of the 10uH coilcraft inductor. Here are the specs:
Current carrying capacity: Type L up to 9A, Type XL up to 35A
Compact design
Low-loss ferrite core
Can be used at frequencies up to 10MHz
Operating temperature -25°C to +85°C
Storage temperature range -40°C to +105°C
Applications: suitable for switched mode regulator ICs from e.g. National Semiconductor, Linear Technology, Maxim, SGS-Thomson, Micrel, Scemtech, interference suppression
stock no=396-3128, inductance (µH) = 10, Tolerance = +-20%, RDC [mOhm]= 17.20, Nominal current Amps= 6.5, Saturation Amps = 10
I used the RS 308-8918 10uH Inductors in mine.
Works fine.
cheers for that are any of there 47uH inductors suitable as well? If so whats the order numbers for them?
Bought the Farnell 482-572 47uH Inductors, couldn't find a suitable RS equivalent.
J
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
