Results 1 to 8 of 8
Thread: DSATX Problem
    Constant Bitrate pimpmode's Avatar
    Mar 2005
    georgia
    DSATX Problem
    I got my DSATX wired up but it doesnt post...It powers up then off immediately like a pulse...The thing is that I have a few wires to choose from...My headunit is one of those screens with a brain...I know I have the right power (yelow) and ground wire (black) but unsure about the remote...I used the AMP turn on wire but their is also an accessory wire (red)...I want to try it out but want to make sure that I dont fry the power supply...So any advice is much appreciated...
    97 Pontiac Grand Prix GTP
    P4 2.4
    Freetech MoBo
    DSATX 220W
    512 MB ram
    200 GB Maxtor harddrive
    Road Runner
    Iguidance 2.1
    EZSync 1.94
    Newbie krustydawg's Avatar
    Apr 2005
    Advice,
    Yeah stop tapping in to wires and run the correct size dedicated wire to the power supply
    krusty
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    Mar 2005
    georgia
    I know but ****s gotta work before i run wires from the battery...no point doing all that work if its not gonna work...tried the accessory wire too and it does the same thing...
    P4 2.4
    Freetech MoBo
    DSATX 220W
    512 MB ram
    Road Runner
    Iguidance 2.1
    EZSync 1.94
    Raw Wave tj!2k4's Avatar
    Oct 2004
    are you out of your mind? you can't tap the teeny tiny little power wire from your headunit and expect it to power the dsatx w/ your system!!
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    the dsatx is a 220 watt max power supply don not expect it to run from these tiny cables.. if you want to test it buy a awg 4 or 6 or 8, and test it with htat.. if you don't want to do all the work try it before you pass the cable through your firewall
    Nov 2005
    Do what Nomader (and everyone else) said.
    Get some very short 8 AWG and wire the DSATX up at your battery (under the bonnet/in the boot). Then run a cheap 26AWG wire from the ACC signal from your wiring harness/loom out to the bonnet/boot where the DSATX is, and connect it to the ACC terminal. That will be enough to test with. Power supply wiring NEEDS to be big enough or dont bother! Signal (ACC) wiring can be very thin. Tapping wires off your headunit harness is a waste of time, and is often dangerous - especially if you are trying to pull ~200W.
    ][ce
    Mar 2005
    georgia
    thanks guys...Will test it from underneath the hood tommorow...What would be the best option for grounding...Is grounding to the battery the best bet or should I find the shortest possible point to the chassis...
    P4 2.4
    Freetech MoBo
    DSATX 220W
    512 MB ram
    Road Runner
    Iguidance 2.1
    EZSync 1.94
    Nov 2005
    GND to the chassis, not directly to the battery. Shortest path wont really matter as this is a test run. but try keep it under 1.5m (4.5ft). And make sure its a GOOD GND. IE: low resistance (<1 Ohm) from the Chassis to the end of the cable you are using.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Weird problem with DSATX and SP13000
    By arawas in forum General Hardware Discussion
    Last Post: 01-15-2006, 05:59 PM
  3. DSATX shutdown problem
    By gameboy in forum Power Supplies
    Last Post: 01-08-2006, 07:59 PM
  4. DSATX: My Mini Review
    By mmdb in forum Power Supplies
    Last Post: 12-29-2005, 12:07 PM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
