Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: opus 150 stupid???
    Oct 2005
    England
    opus 150 stupid???
    is my opus stupid??? my GPS is always on and my CD drive even though my iginition is off, after a few days this is draining my battery, is my opus stupid? or is this normal? or is there a jumper i can change a setting?
    all fitted but its having a wobler!
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    its normal the opus doesnt shut down the 5v line. Have a search and you will find a design to put a relay and some diods on the power supply that will cure this. I think you can send it back to opus and they can change the firmware that will shut the 5v down too.
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    try this
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by pardoe16V
    Subscribing...as this used to happend to me sometimes.
    Raw Wave tj!2k4's Avatar
    Oct 2004
    same here. what's the diagram mean? sorry, I'm electrical-schematically challenged..
    Jan 2005
    Scotland
    the bit between the opus and the computer is the circuit you make. Its a relay and 3 diods. So long as the mobo is getting 12v the relay is closed and the sytem gets 5v. When the opus shuts the 12v down the relay drops out and the 5v line is cut. When you put your ignition on (ACC) the relay sees 12v again and closes the circuit reconecting the 5v as well as the opus switches the power on so it all boots up.
    So from a cold boot you get
    ACC on relay closes and power supply boots everything up.
    ACC off (you switch the ignition off) Relay stops seeing the ACC but still gets 12v from the opus, the opus stops seeing the ACC and shuts down or hibernates the pc. When the pc has shut down the opus shuts off the 12v power, the relay is now no longer getting 12v so it opens and disconects the 5v line.
    No more power drain and your battery stays charged.
    Low Bitrate jay_tu's Avatar
    Dec 2004
    Towson
    This doesnt happen with mine ......... may be the 5v line is on... but the cd drive and gps are off with the ignition.
    04 Corolla
    Modifications:
    Upgrading pc 99%
    Progress
    May 2005
    Chico, CA
    Is this fixed with the newer ones? I haven't hooked up my GPS/CD-ROM yet.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Dec 2000
    pittsfield, ma.
    i'm albysure84 on im. usually on at night. i can explain it to you better
    Oct 2005
    England
    cheers matey
    I dont use this forum much but it always come in handy!
  1. DIY Opus 150 5v Stndby power cut mod
    By antimatter in forum Power Supplies
    Last Post: 08-31-2005, 11:00 AM
  2. Should I ditch my Opus 150 for my CF-bases system?
    By ayclens in forum Power Supplies
    Last Post: 08-22-2005, 11:30 PM
  3. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
  4. Opus 150 and Netstumbler hibernate/shutdown problem
    By slick rick in forum Power Supplies
    Last Post: 03-28-2005, 10:54 PM
  5. Stupid question about OPUS wiring
    By RS3RS in forum Power Supplies
    Last Post: 08-31-2004, 02:33 PM
