Results 1 to 10 of 17
Thread: m2-atx doesn't survive crank, used to. why?
    Dec 2005
    Australia
    Angry m2-atx doesn't survive crank, used to. why?
    This is really annoying!! My m2-atx was working fine, but occasionally it reboots during crank, in a brand new forester xt06.
    Any ideas? This seems to occur for a while, then for no reason it starts working fine again and survives the crank.
    Is the damn thing faulty?
    I put a DMM on the terminals of the pc during crank and the voltage dropped, but not very much. Can't remember exact amount, but it wasn't below 11v from memory.
    Thanks for any help
    Cheers
    Jamie
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Battery voltage is too low.
    could be the battery on the way out or just drained at that time. Take it out for some long drives to chargew it up.
    I had/have the same with my inverter, it normally survives the crank no problem but if the battery is quite low it doesn't.
    Dec 2005
    Australia
    The battery should be fine, the car is only 3 months old, almost.
    But you might be right. I will measure the voltage drop during crank today.
    The qustion is, how low is too low? I thought in the manula it said it could survive down to 9v or something during crank???
    Who makes these PSUs? I would like to contact them direct
    Cheers
    Jamie
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    My car drops down to around 3v during crank even after a nice long drive. While mine is pretty low, dropping to less than 9v for most cars is not unusual.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Take the car to a parts store that will to a free charging system diag test.
    It will tell you about the health of your: battery, alternator and voltage regulator.
    It takes about 5 minutes and will help you answer your question.
    Even 3 month old batteries can be bad, though it can be caused by another part of your charging system or too much drain.
    TruckinMP3
    Read the FAQ!
    Dec 2005
    Australia
    OK just tested the battery during crank. It goes down to 9.12V. Its 12.03 after sitting in the shed all night. 14.++ while the car is running.
    The m2-atx manual states it can handle down to 7volts during crank. Not getting anywhere near that.
    After all this now the damn thing works again.!!! It worked after sitting all night, but it won't work after I drive the car for 20 min, which should charge the battery right up.
    Hmm, starting to think this is just a faulty POS.
    So, who produces these things?? Anyone know? I bought it from MP3car.com, but I would rather deal direct with the manufacturer if I can.
    Jun 2002
    Colorado
    if it is bad after driving go get your car tested. You may find something in the charging system is broken.
    Do this before you get stranded.
    TruckinMP3
    Read the FAQ!
    Jun 2002
    Malaysia
    I'm betting my money that your cables are too thin or too small.
    A good amount of ampere needs to run to compensate for the drop in voltage.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Chances are that there is something wrong with your cars' charging system and the CarPC is not at fault, but it is more sensitive to the voltage drop. Check your connections to the battery. If any are loose or corroded that could cause this. Wiggle the wires leaving the battery and follow them to the other end and check there too, especially where the ground wire goes to the chassis.
    ~Jimmy
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Check the wiring and make it as short as possible and w/ heavy gauge (at least 10g) . I've had my system for 1 1/2 yr and never had a failed crank since I used good wires. I also have a yellow top optima
    08 Lincoln Navigator www.mobiteklink.com
  1. M2 ATX - EN15000 - USB - Problems!
    By BulleDK in forum Power Supplies
    Last Post: 12-28-2006, 04:29 PM
  2. Does your M1-ATX survive crank?
    By acura cl in forum Power Supplies
    Last Post: 04-06-2006, 09:58 PM
  3. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
  4. Optima Battery survive crank
    By michaelrj9 in forum Car Audio
    Last Post: 04-13-2005, 06:44 PM
  5. Using a high farad cap to survive engine crank
    By lakorai in forum Power Supplies
    Last Post: 03-28-2005, 10:47 AM
