Results 1 to 2 of 2
Thread: Portawattz 300 watt
    Apr 2002
    Charlotte, NC
    Portawattz 300 watt
    I looked at this inverter, and I was all set to buy it, until I noticed one thing. It gives 115VAC out. The norm is 120VAC right? Will it still power a computer and a basic household bulb at the same time without problems?
    Silver 1999 Nissan Pathfinder!
    Completion: [*********-] 90%
    Everything working! Mobile MP3s ROCK!
    LEFT TO DO: Improve power on circuit, fix slow boot time
    - 550mhz PIII on Abit BH6
    - 128MB RAM
    - 40x4 Backlit Character LCD
    - 17 key numeric keypad - Repainted buttons
    - 2.1GB laptop drive for OS
    - 4.3GB drive for MP3s
    http://www.mp3car.com/usersites/bombboyer/ Redesigned, new pics!
    Constant Bitrate jboy's Avatar
    Oct 2001
    MA
    US home mains can be 110Vac to 120Vac as rated by your supplier and where you live, most equipment can live on 100-130V though.
    I've had power issues here and recorded swings from 95v up to 142v the power Co. said it's because I live near a switching station.
    It still blows out bulbs real quick.
    The bigger problem is alot of inverters don't produce a true sine wave. they may output a modified square or triangle waveform, some AC power supplies can deal with this and others won't and unless someone here has the same combo you plan to use you won't know till you try or chec the inverter output with an O scope.
    If you come out talking sh1t don't try to turn around and wipe you azz.
