cant help you out with the circuit but resistors don't limit voltage they limit current. Voltage drops in a circuit due to resistance because you are trying to take too much power from the circuit.
To visualise this think of water in a pipe with a tap.
Voltage is the pressure you feel when you put your finger over the pipe.
Current is the amount of water coming out the pipe.
The resistor is the tap.
Now imagine you turn the tap so you just get a trickle out the pipe. There is hardly any current there I.E not much water coming out the pipe but if you put your finger over the end there is just as much pressure.
LinkBack URL
About LinkBacks
