Results 1 to 4 of 4
Thread: Opus Wiring into Dist. Block
    Nov 2005
    I am almost done with my car pc setup but came across a snag that i couldnt find a direct answer for after searching a long time. I wiring the opus into a distribution block. I'm not that good when it comes to dealing with wire step downs...going from one gauge to another and placement of fuses. The image below shows the opus 120w 2-16 gauge wires connecting to a 10gauge wire with fuse in between the 10gauge wiring and into the distribution block. Or since its only going another few inches to the distribution block-should i just run the 2 16 gauge wires right into the 8gauge spot and put the fuse in. Its hard for me to find any 15gauge AGU fuses local. PLEASE HELP
    Mar 2006
    Colorado, but Canadian!
    If I were you, I would delete this double post or you will be flamed and eaten alive by moderators.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2005
    i posted on the other thread to delete it due to double post.
    Elsewhere
    Quote Originally Posted by speed_krazy View Post
    If 16awg wire will it in the connectors, then go for it.
    Personally, I think 16awg to provide power to the Opus 120w might be a little on the small side. I'd suggest at least12awg for a short run, 10awg for a longer run.
    Taken care of.
    How about the Wiki?
  1. Opus 120 and MTSVO-SC, wiring questions
    By 01black_ac in forum Power Supplies
    Last Post: 03-22-2006, 08:36 PM
  2. OPUS wiring question
    By Slitha in forum Power Supplies
    Last Post: 01-11-2005, 03:47 PM
  3. Opus wiring to Sub
    By H3nrY in forum Power Supplies
    Last Post: 08-05-2004, 03:55 PM
  4. OPUS 90W wiring!! PLEASE HELP!
    By GMCVOY in forum Power Supplies
    Last Post: 08-05-2004, 10:55 AM
  5. Specific Opus wiring question
    By rdc_3200 in forum Power Supplies
    Last Post: 07-24-2004, 05:12 PM
