Results 1 to 4 of 4
Thread: problem with power opus power supply in the car
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    Unhappy problem with power opus power supply in the car
    when I power on the cpu in the car, it starts to turn on then shut off. The green light on the opus 150 power supply blinks three time in a row. which tells me theres a problem with the voltage or power supply. Well I know it not the power supply, because I hooked the cpu on the desktop in my house, using dc-power 15amp power supply, and it worked normal. started up fine. In the car its a differant story, which has to be the voltage is out of range. how would I be able to correct this?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Have you checked the voltage your supplying the opus with? If not get a meter and test it.
    Where are you currently running the supplies from and in what size cables?
    Make sure you have a good ground.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Oct 2005
    I found the problem with my carcpu. it was a bad ground. thanks for your help.
    Jan 2005
    Scotland
    Smile
    No problem, Least it was something simple in the end.
  1. Opus Power Supply Issue
    By Master X in forum Power Supplies
    Last Post: 06-27-2006, 08:19 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. FS: 90watt Opus Power Supply
    By Nico3k in forum Classified Archive
    Last Post: 03-09-2005, 08:23 PM
  4. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  5. Power Supply Without Opus
    By chewy747 in forum Power Supplies
    Last Post: 09-15-2004, 04:45 AM
