Results 1 to 7 of 7
Thread: Can't Go Past POST. What's Wrong?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    I bought an external 2.5" enclosure which works from both USB and firewire. It has an external power connector as well as the USB cable.
    So I plugged into my PC, and it wouldn't go past POST. However, if I let the PC get past post, then plug it in, it works fine!
    I thought, this must be that there's a powersurge at startup and the mobo doesnt' want to proceed. So I went and bought a second M2-ATX, an 8-port hub, and used the M2 to power the hub, and the HD enclosure.
    My mobo has only the hub connected to it, and all other devices are plugged into the hub. Other devices are GPS, IBUS, TS, KB. And the same thing happens! If I plug the HD into the hub, then it doesn't go past POST. If I unplug it, then plug it in after POST, then it's fine! Even just the HD on the hub locks it up.
    Does anyone know what the hell is going on? I thought that if I used a hub, the motherboard will not care about external devices being underpowered etc.
    I think this has something to do with the rules of USB devices and how they register themselves with the amount of power the draw at the start. Anyone have any insight?
    Elsewhere
    Check USB boot in the BIOS and make certain it's disabled.
    Also make certain USB devices are not listed in the boot order at all.
    How about the Wiki?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    yep, only boot device is the compact flash card. all others are off.
    Maximum Bitrate Rundell's Avatar
    You might want to try to see if there is a newer BIOS out and try updating it.
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    FLAC sama's Avatar
    Feb 2006
    London, UK
    sadly there is no update
    but perhaps I should take this up with my mobo manufacturer, or even revert to an older bios and try it.
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    Disable USB Legacy Support in the BIOS, on most Dell computers this can cause problems with printers that have flash card slots. Since you are running an external drive it could be the same type of problem.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    not sure I've seen that opiton in there, but I'll look.
    car's at the stealer currently, and I'm off for a Eurotrip tommorow evening. hopefully this will solve it if it's in there.
    cheers for the info
  1. m2-atx failure? mobo doesn't post..
    By bmbr in forum Power Supplies
    Last Post: 08-05-2006, 07:43 PM
  2. nOOb with power problems..sorry for the long post
    By hank_kls65 in forum Power Supplies
    Last Post: 03-23-2006, 10:39 PM
  3. Forum Etiquette
    By Enforcer in forum Newbie
    Last Post: 01-09-2006, 06:58 PM
  4. Replies: 22
    Last Post: 01-05-2006, 09:26 PM
  5. Cant edit post in FireFox
    By liquid_smoke in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-10-2005, 12:23 PM
