Results 1 to 10 of 12
Thread: Problem with battery drain
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    This is a tricky question for me since I don't know what area it should go in.
    I'm having battery drain overnight from the computer. More comments below my diagrams. I have a M2-ATX PSU.
    Diagram 1 shows how I supplied power to both the PC and AMP. I'm using a lilliput in-dash screen so the power for that comes from the radio harness
    http://www.911pcrepairs.com/images/car_in.jpg
    Diagram 2 shows how I power the rest of the devices in the car
    http://www.911pcrepairs.com/images/car_out.jpg
    Computer turns on fine after cranking. Amp works , screen works. PC Boots, hubs are active, everything works. If turn off the car the PC shuts down and the amp goes off. The USB hubs remain powered and you can push the button to open/close the USB-CDROM and it opens/closes. That tells me that there is still power coming from the PSU. One HUB has a blue LED that glows so I know it is active.
    The setup does the SAME thing if you use the Shutdown in windows to power off the PC.
    Whats going on? The power only stops if you unplug the red wire to the PSU and then plug it back in. What gives? If I dont do that unplug and plug in step the computer drains my battery overnight and the next morning its a dead batter (thank god for a battery jumper).
    Feb 2006
    I had the same problem when using the onboard supplied usb ports. Although my battery didn't drain, but it was very annoying because my usb hub has a light and u can see it at night from outside the car. To fix it I used the USB ports that are supplied by the computer's case (the ones that connect to the motherboard). Or maybe if you buy a pci usb card, that might work.
    Mar 2006
    Palm Harbor, FL
    The Hubs arn't getting their power from the USB cable, they are powered by the power jack. This tells me it is something to do with the PSU because my CD-Rom HAS to be plugged in to work. The amount of power supplied by a single USB port isn't enough to power my device.
    That said, it is either something wrong with my wiring, a faulty PSU, or I simply don't know what.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Quote Originally Posted by Splash-X View Post
    The Hubs arn't getting their power from the USB cable, they are powered by the power jack. .
    Did you modify your USB cable or HUB to eliminate the connection to +5V supplied by the mobo?
    If not the hub is drawing power from your psu standby circuit.
    Quick check- pull the USB cable from the pc for an overnight.
    Mar 2006
    Palm Harbor, FL
    No modifications were made to the hubs so I'm assuming that I will need to do that.
    A side question, would a better idea be to some how place a switch on the power cable running to the computer? That would also allow me to turn on/off the PC if needed without shutting the car on/off.
    May 2005
    USA
    The mod to the USB cable is pretty quick / painless. You just have to figure out which of the 4 wires is the 5 volts and cut.
    I use a switch on the dash to control a relay that makes or breaks the 12volt connection to my psu. My car had a cd changer option in the truck so an unsued cable that runs from the dash to the trunk carries the relay signal, as well as power for my LCD and USB hub.
    Newbie Timecloud's Avatar
    Jul 2006
    I would say that putting the switch on the power lead to the PSU would be your best/easiest solution. It would also let you turn it on/off at leisure.
    2000 Excursion 4x4 Limited V10
    Generic DVD
    2 7" Headrest monitors
    Acorp 7km400QP 2500+ 1GB DDR400 - m1ATX
    Delorme Earthlink GPS
    XM-PCR1000
    7" TS
    Worklog
    Mar 2006
    Palm Harbor, FL
    It has been a long time since I've done switches for things in the car. I've installed many fog lights in the past and neons but we're talking 7 years and I was a novice.
    A switch would be the equilivent of running the red power to the switch, ground the switch, and then run the power out to the computer. Is that right?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    If the switch has a light in it, yes. Otherwise it's just going to have two prongs, just an in and an out. So one prong would go to the battery, the other to the PC
    May 2005
    USA
    If you are doing a switch you need to know how much current you are drawing. The greater the load the larger the switch. If the switch becomes too large for your planned location ( dash etc ) you will probable want to use a relay.
  1. Powering car from a 13.8V power supply ok?
    By PURDooM in forum Power Supplies
    Last Post: 06-12-2006, 11:56 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  3. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 02:47 PM
  4. time to a dead car battery?
    Last Post: 08-20-2004, 10:08 PM
  5. Replies: 3
    Last Post: 08-04-2004, 04:52 AM
