Results 1 to 6 of 6
Thread: datalux in car power
    Dec 2001
    Columbia, Maryland
    Question datalux in car power
    hey i purchased a datalux 10.4 " display from typhoon747. he runs an inverter, i do not (DC-DC) i was wondering if i could take the 12 volt power from the computer and use that. specs for the "wall wart" are 12 volt DC @ 1 amp output. could i just wire up a plug to the power supply and be done with it? i dont want to blow the ***** up. thanks
    Sep 2001
    You could do that, or you could do like I did, and use the cigarette lighter wiring to power it. The datalux monitors are industrial, and made to be used in cars. They will operate at 13.5V nominally just like your car's electrical system will produce while running.
    Dec 2001
    Columbia, Maryland
    i'd like to use the "clean" power from the power supply, its 250 watts so power should be ample. just wanted to see what every one else was using. any one else?
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    Cigarette lighter power adapter from Ratshack, works for me.
    Link
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
    Sep 2001
    He could definitely use the cigarette lighter, datalux is very aware of how 'clean' a car's electrical system is and designed the monitor with those ideas in mind.
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    even though my carputer is still on the corner of my desk,
    i use the yellow and black wires from the power supply and its fine
