Results 1 to 3 of 3
Thread: Car PSU HDD and FDD / DVD Power Connectors
    Aug 2006
    So, are most of the HDD and FDD power cables for the car PSUs all 5V? I believe I read that the 2.5" HDDs common to laptops and carputers run off of 5V, whereas a standard 3.5" HDD uses 12V. With that in mind, are the HDD cables set to use 5V or do you really have to split the FDD cable to go to the HDD and DVD? If both are configured for 5V, how are folks connecting their TS to the PSU?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    o_O
    dunno where ur getting ur information from..
    but the car psu's output 12v on the molex connectors, not 5v
    yellow = 12v
    black = ground
    black = ground
    red = 5v
    so to get 5v, u just use a red and black
    but yes, 3.5" generally are 12v, 2.5" generally are 5v, and as far as i know, the 2.5" power adaptors end up using the red/black wires and not touching the yellow
    and most touchscreens need 12v, so that means you would tap the positive line from the touchscreen, into the yellow wire, and the ground from the touchscreen to one of the black wires
    Aug 2006
    I understand that the molex that connects to the mobo is 12V, but there should be two additional connectors, one for FDD and one for HDD. On a home desktop based PSU, these separate connectors are wired correctly for the appropriate voltage of the connected device, either HDD or FDD. I'm asking if the car PSUs are the same way, or is it a cut and solder job to get the correct connections?
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  3. Standard HDD to FDD power adaptor?!
    By coachreed in forum Power Supplies
    Last Post: 06-10-2004, 05:11 AM
  4. Adding a hdd connector to PSU
    By guitar333 in forum Power Supplies
    Last Post: 08-05-2003, 10:18 PM
