Results 1 to 2 of 2
Thread: Opus ignores ignition wire, constantly stays on
    May 2005
    On the Opus 150W DC-DC, I have the black wire properly grounded (triple-checked with multimeter), the power wire connected to the battery and the yellow wire spliced into a headlight ACC wire. I've tested and confirmed that the ACC wire to yellow Opus wire works. When the ignition is on, 12V. When it's off, no voltage.
    With the car off, the Opus turns on the computer the moment I plug the harness into the Opus. It's like it's ignoring the signal from the yellow ignition wire, even though I've confirmed the wire is getting 12v only when the key is turned to accessory.
    Naturally, turning the ignition off doesn't shut the Opus off either.
    Any ideas what could be causing the Opus to function like this?
    Variable Bitrate redls1bird's Avatar
    Feb 2006
    just a thought, but try a different acc wire. that will indeed show that it is the opus and not some obscure problem with your cars headlight wiring.
    Car Pc progress meter:
    [-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  1. opus remote wire doesnt turn off amp
    By evilragu in forum Power Supplies
    Last Post: 08-17-2006, 04:44 AM
  2. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  3. Need to find acc wire that stays alive during crank.
    By Bobby Digital in forum Power Supplies
    Last Post: 02-05-2004, 06:42 PM
  4. What gauge wire for opus?
    By XxAndyxX in forum Power Supplies
    Last Post: 01-20-2004, 12:21 AM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
