It's possible. I measured mine once and it only drew about 4 to 6 amps. Depends on the system, and the efficiency of the PS, and what is going on computer wise, such as DVD spinning, HD spinning, CPU load high, graphics rendering, etc....
The MII is a low power system, your HD is 5 volts, not sure which buffallo your using, but if USB, it is also 5 volts. Remember, wattage is ampsXvolts. If you are using 5 volt devices, then the total wattage will be little, and then since your car is supplying 12 (well, really 13.8 bolts when charging) you divide the total wattage by 12, to determine total amps, and of course, you have to add in the efficiency, but you get the idea I am sure.
Michael
LinkBack URL
About LinkBacks
