Alrighty, i'll preface this by saying i know enough about electronics to be dangerous
I am starting my first carputer install, i am using an old compaq armada
laptop.
The problem i have run into is that my invertor won't start, not for the life of me.
It is a generic 350Watt invertor. I have connected it to the fuse for the blinkers (for it's 12V
power, i used the blinkers because they only work when the car is on, and that way i don't have to mess around with flipping a switch to use the invertor, it will just be on when the car is on) and grounded it securely to the cars frame. I have tested the power and ground leads using a voltmeter, and it's a solid 12 volts, so i know the ground and power are good. I have connected the invertor the the cig lighter in my wifes car, and it works that way. i have connected the invertor directly to the battery, and it works that way. i have taken the power and ground leads and connected them to a little 12V light, and it DOESN'T light
I can't figure it out, the voltmeter says that i have a solid 12 volts, but It won't light a bulb let alone power my invertor
any help/suggestions will be greatly appreciated
