Did u read the M2 manual and the jumper settings?
When I turn on my ignition, my 5v rail turns on immediately but my motherboard doesn't turn on. If I turn the Ign off and back on before my powerdown interval, it powers on fine. I believe that my motherboard needs a second or 2 after getting power before it's ready to post. Does anyone know exactly how long after Ign goes high that it initiates PwrOn? Anyone seen this before? I also have some weirdness with EMI on my monitor that is power supply related. Maybe I just have a bad M2.
My board it a WinFast NForce 4 Ultra with an Athlon 64.
When that happens, do you see a black screen with just a blinking cursor? I think I'm having the same problem as well. It doesn't happen all the time, jus occasionally so I don't know what to do?!
No, it sinply doesn't power on. I can go short the pins to initiate poweron just fine and if the 5v rail is already energized, it will power on. The only time I see this is when I tru to start after the 'hardoff' time interval has expired. As a test, I put this on a 110v poer supply and tried to time how long it takes for the motherboard to accept a poweron after power is applied to the ATX connector. It is somewhere around 1 second.
Anyone out there have a nForce4 board working ok with an M2 ATX?
