give us a little more details..
did your system work succesfully? 1 week?
what is your configuration?
checked the input voltages?
checked for cut or burned wires reaching to your DSATX?
did you have a big fuse near your battery?
Hello all:
My Dstax not working after one week with no problem.
I tried to resest it by puting a jumper on pins A2 and B2 (nothing)..then I tried the Dumb PSU Mode by puting a jumper on Location B still nothing.
I checked all conections they all fine.Next I will get a new 20A fuse maybe it was some kind of reverse voltage....but the fuse looks fine no burning marks or any thing.
Help please
Essam
I am running Pundit P1-PH1 w/ 3.0 intel processor, 512 memory, 120g hard drive and one optical dvd drive.
it worked succesfully for one week.
I did not checked the input voltages.
I did not see any cut or burned wires.
I do not have a big fuse near the battery.
I hoked the system to the orginal PS and it worked fine.
thatnks for all the help
Essam
MPEGBOX - Plexiglass Computer
www.mpegbox.com
ok I am home now![]()
the sricker on the back of the Dsatx says D 482606
thanks zootjeff, hopfully there is a salution for this thaks again.
www.mpegbox.com
www.mpegbox.com
I only tried in the car and it's not working (No LED) and I used the same connections that I used when it was working
Let me see if I can setup someting inside as far as AC/DC adapter maybe something wrong with the car connections.
But if it didnt should I just go ahead and send it back to the the store where I got it from or you have another option, thanks.
