Results 1 to 3 of 3
Thread: M1-Power Supply Not Always Working
    Jan 2006
    I have an M1 power supply.
    Sometimes it works... sometimes it does not.
    And by that I mean that sometimes when I turn the car on it goes (80% of the time).. the remaining 20% it does not start up.
    And the shutdown is about the same.
    I have checked all the connections, jumper settings, etc and all seem good.
    One theory is that my ignition line is not giving me enough juice to start things (the intermittent problem).
    One idea I have is adding a micro startup/shutdown controller. My hopes is that it will be more sensitive in the ignition signal, and provide a 12V constant.
    Any suggestions on this?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by msreyes View Post
    As you are probably aware, intermittant problems are VERY difficult to diagnose and fix.
    I would do the following to test it,
    Take a wire from your battery, run it into the car, or perhaps, if you just want to leave the car parked, and run the wire from the battery to the PS along the outside for testing only, do that, run it to the ignition/acc wire of the M1. Put a switch in that line, so that you can turn it on and off, and just test the M1. Let it boot, let it shutdown. If your suspicion that it is the accessory wire is the culprit, this wire will prove or disprove it. If you still have about 80/20 success, then you know it is not the accessory wire.
    Then, I would disconnect the switch wire that runs from the M1 to your MBs switch header, and install a seperate switch, like form a computer case, to it. Leave the M1 powerd by the accessory wire (or the one you previously ran to test it) and then push the button. Again, see if you still have 80/20 success rate. That will tall you if there is a problem in the connection between the M1 and the MB switch header.
    Other then that, just confirm that all your connections are solid between the battery and the M1.
    Michael
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Another suggestion: if you have another 12VDC source available, test using that instead of the car/battery. This will help determine whether the problem is the car or the PC wiring.
    ~Jimmy
  1. New Mpegbox Power Supply
    By zootjeff in forum Power Supplies
    Last Post: 09-20-2005, 01:32 PM
  2. Do I need another power supply
    By gdawg in forum Newbie
    Last Post: 08-27-2005, 08:25 AM
  3. Choosing a power supply now.
    By Osiris in forum Power Supplies
    Last Post: 01-31-2005, 06:51 PM
  4. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  5. AT power supply questions
    By JustAGuy in forum General Hardware Discussion
    Last Post: 07-26-2000, 05:35 AM
