Results 1 to 10 of 14
Thread: M2-ATX not enough juice. What can I remove?
    BGH
    BGH is offline
    May 2006
    Melbourne, Australia
    After finally installing my Carputer it seems my M2-ATX isnt quite providing enough power. It looks like it almost is, it can run for around 2 - 3 minutes but then shuts down.
    Here is what I am running
    Gigabyte PCV2 mini-ATX mobo/CPU. This is a strange one. You wont find anything about it on the web/google etc. I contacted gigabyte about it and apparently it was an OEM board originally used in some DJ equipment or something. Anyway it has a 1ghz CPU and looks pretty much the same as an M10K. Using onboard VGA and Sound.
    Panasonic slot load DVD writer
    1 x 512 PC3200 RAM
    8 inch touch screen
    Radio X-Treme
    BU353 USB
    120Gb Seagate 3.5" HDD
    and that's it.
    I thought with the M@-ATX there would be plenty of headroom to play with there but obviously I was wrong.
    I guess I could use a notebook drive but I have the 3.5" one mounted in there now and it would be a pain to change it.
    I could also connect the screen up directly to the battery. Although it really would be derirable to have it run off the PSU.
    Any suggestions?
    Aug 2006
    Well you're on the limit. I've a very similar configuration, and i'm on the limit too, but didn't experienced any problem.. until now:
    EPIA M10000 (1ghz)
    1 x 512MB PC3200 RAM
    7" monitor
    GPS BU353 USB
    80GB 3.5" HD
    PCI Wi-Fi Card
    USB External DVD Recorder
    USB POWERED HUB (5v rail)
    USB Bluetooth dongle
    USB Mini-Mouse
    USB Mini Keyboard (no need any serious power)
    I guess i uses less power on the monitor and HD, i don't have the radio card, but i have the Wi-Fi card (it would uses less power than a radio card), but also i have a HUB, the BT dongle, the mouse and keyboard.
    A solution for you, that will work for me too if i don't burn my M2 before, is to switch from the 3.5" HD to 2.5"... you will save enough power... or add a second M2 to power only the HD, DVD and Monitor.
    BGH
    BGH is offline
    May 2006
    Hmmm, this really sucks. I'd prefer not to switch to a 2.5" drive as I have the 3.5" mounted just right. But on the other hand I really want to run the screen off the M2-ATX so the HDD is the only thing I can change
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by ARCTiC View Post
    EPIA M10000 (1ghz)
    7" monitor
    GPS BU353 USB
    80GB 3.5" HD
    PCI Wi-Fi Card
    USB Mini-Mouse
    You are severaly taxing your 5v rail. Try a POL, you can get them in the MP3car.com store.
    Your HUB takes some power to run, and each USB device is half an amp, and that DVD probably needs an amp of power. In addition, your MB (possibly also the memory) are using the 5v rail.
    You should run a power calculator (do a search on that, there is alink with about 5 of them) to see what you are using. The m2 has 8 amps available on the 3.3, 5, and 12v rails. ALWAYS OVER ESTIMATE what the items require, NEVER underestimate.
    Michael
    May 2006
    Calgary, Alberta
    I have the M1-ATX with only 90 watts and I'm running my 7 inch screen, Wi-Fi USB, GPS USB, keyboard, and on board sound/video.
    Are you sure it's just not heating up the chip or wire to the point where it cuts out?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    BGH
    BGH is offline
    May 2006
    Doubt it, when I unplug the DVD drive it runs fine.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by BGH View Post
    There is your answer. If your DVD drive is USB powered then the problem is you are running out of juice on the 5V rail. What do you NEED the DVD drive for anyway? You can get a point of load supply just for the 5V.
    ~Jimmy
    Aug 2006
    Quote Originally Posted by Wiredwrx View Post
    Michael
    Yop i know i risk, what i doesn't know is if i'm really out here, this should be my peek on 5v rail (i didn't considered the shared voltage on 12v and 3.3v rail because they are fine, this one are only the drain on the 5v rail):
    Mobo: 1A
    RAM: 0.4A
    Wi-Fi: 0.4A
    3.5" HD: 0.9A
    DVD: 1.2A
    USB HUB: 1A
    Keyboard: 0.05A
    Mouse: 0.05A
    GPS: 0.08A
    BT: 0.08A
    TOTAL: 5.21A
    That's if my data aren't completely wrong.. i hope i'm not!
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    I'd try POL of 5V. You can buy 12VDC to 5VDC regulated PSU for real cheap, if you can wire things up yourself.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Mobo: 1A
    RAM: 0.4A
    Wi-Fi: 0.4A
    3.5" HD: 0.9A
    DVD: 1.2A
    USB HUB: 1A
    Keyboard: 0.05A
    Mouse: 0.05A
    GPS: 0.08A
    BT: 0.08A
    TOTAL: 5.21A
    Calculators are not 100 percent accurate, so try not to be so precise when you do the numbers. Kinda like what I said before, round up, not down.
    Also, USB is spec'd at half an amp each. Go with that number if you can.
    The other thing is, remove one device at a time, and see if you can boot. You might figure out which one is a power hog. Then you can try a non USB device if possible, or get a POL, or perhaps get a different brand of the same, that might be less power hungry. In any event, running anything near it's rated specs for extended periods of time tend to shorten the life of devices. The less you tax any electronics, the better.
    Michael
  1. M2 ATX - EN15000 - USB - Problems!
    By BulleDK in forum Power Supplies
    Last Post: 12-28-2006, 04:29 PM
  2. M2 ATX Manual
    By lanman1 in forum Power Supplies
    Last Post: 08-16-2006, 02:28 PM
  3. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  4. WTB m2 atx
    By ampy549 in forum Classified Archive
    Last Post: 05-21-2006, 02:44 PM
  5. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
