Results 1 to 3 of 3
Thread: Power Supply problems
    May 2002
    Angry Power Supply problems
    Hi,
    I hope you guys can help me. I have built a power supply based on the MAX787 IC. You can see it here http://www.jarcom.com/inmotion/power.htm
    Now, instead of using a 50uH inductor (which I could not find), I used a 47uH instead (with a 10% tolerance) thinking that this should be ok.
    When I plugged it in with no load it was ok abut when I connected it to the computer, the inductor burned up quite quickly. I tested what current the PC is drawing and it is only about 2.5A or a little less -- this is well within the 5A load limit.
    Do you guys have any idea's before I do get another inductor and try again.
    Thanks a lot,
    c-dawg
    FLAC Mastero's Avatar
    Aug 2001
    India
    what is the amp rating on the inductor? should be atleast 5amps min
    also check for shorts on the board
    Mastero
    May 2002
    Thanks!
    The current for that inductor was < 0.1A !!
    No wonder it turned into fried silcon!
    I have order a 7A inductor but it has to ship to me and it will take a week ok well -- I guess I will have to wait!
    Thanks again,
    C-Dawg
