Results 1 to 2 of 2
Thread: 8awg to 18awg wiring using fuses
    Nov 2005
    I've read many threads about wire gauges and what fuse to use, but I've seen different opinions on how to deal with a larger wire going to a smaller wire.
    Specifically, I have 8awg power wire from battery that will be connected to the m1-atx power wire lead (which is 18awg I believe). There is a 10A fuse on the m1-atx and I will be using a 10A fuse on the 8awg power wire by the battery. It is ok to just solder these different gauge wires together right? But, I've heard that any change in wire size should be accompanied by an in-line fuse. In this case, is there a need for another fuse in between the 2 wires? The 18awg wire from the m1-atx is only a foot long. I'm thinking that it isn't necessary because there is a 10A fuse by the battery and on the m1-atx, so it doesn't make sense to put a smaller fuse than what is on the PSU.
    Is my thinking here logical or am I confused? I just want to be as safe as possible. Any comment appreciated, thanks.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    just get a distro block, a lot of them have fuses anyway
    they can take 8gauge and output to 2-3 18gauge wires (for future upgrade )
  1. Carnetix 1260 Wiring Question
    By dante19 in forum Power Supplies
    Last Post: 03-02-2006, 11:45 PM
  2. Replies: 8
    Last Post: 02-14-2006, 07:43 PM
  3. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  4. wiring 8awg to a switch...connectors???
    By hud in forum General Hardware Discussion
    Last Post: 05-26-2004, 08:03 PM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
