Results 1 to 9 of 9
Thread: Powering xbox with M1
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Exclamation Powering xbox with M1
    I found that diagram and basicly understand it but i still need some help.
    I know the blue circles are resitors, but i need to know what the top and bottom green circles are and what the top, middle, and bottom red circles are (and where i can get all of these online). I also need help with the jumper wires from the m1 to the xbox. Do i just connect them to where the normal power buttom connects or what? Thanks alot, Drew
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    green circles should be capacitors
    the red circle in the middle looks like a transistor
    the other 2 red circles, are voltage regulators
    if you go to xbox-scene.com you'll find a tutorial for this, as well as someone else on this forum got it to work.., forget who it was now, but find out and pm him, he might help u
    Oct 2006
    just curious if there are any updates on this.. i would like to do this to my xbox as well.
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    Quote Originally Posted by mayson14 View Post
    you might be better off just modding the power wires directly into the Xbox's internal power supply...
    the reason people use the m1 is really because of the on off switch.. which i dont think even works in xbox's (they have a different connector)
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    Jan 2006
    connector, shmenector. it works
    Mar 2006
    Iowa
    Quote Originally Posted by jetlounge View Post
    I've seen that install it's nice. Is it yours?
    1998 Camaro Worklog Starting over, New setup for 2010
    Jan 2006
    Yes that's mine.
    Mar 2006
    Iowa
    can you go more in depth with you wiring diagram? I'd really like to do this now that i have my screen in. Thanks
    Mar 2006
    Iowa
    Well i have my carputer running and i would now like to try this out. Can someone help me with exactly what resistors, capacitors, transistor and voltage regulators i need? I want to get my parts list together so i can order everything. Thanks
  1. XBOX + Apache v2.6 + M1-ATX = problems?
    By arionl in forum Power Supplies
    Last Post: 07-18-2006, 12:46 PM
  2. M1 + Xbox
    By Giant in forum Power Supplies
    Last Post: 09-22-2005, 04:25 AM
