Results 1 to 4 of 4
Thread: Car PC power Line
    Aug 2006
    Car PC power Line
    fitted a car pc other day the power line is fused but was just wondering shall i put a swich on the power line ? or is the standard mother board switch good enough
    Elsewhere
    That depends... Do you want a switch to completely kill power to the PC?
    Also, remember that you're going to need a pretty beefy switch to handle the current going to the PC. A low-current switch (such as the one that powers on the PC) isn't going to be able to handle the current going throught the power line.
    How about the Wiki?
    Aug 2006
    i just dont want the pc burning it self out ? when i turn the standard button off the pc off the wifi usb light is still on
    Elsewhere
    PCs don't burn themselves out. I leave my PCs at home on 24/7 nless I'm away for an extended period.
    Your Wifi light is still on because there is +5v still going to the USB devicves. That means your PC is still drawing current (albeit a small amount, I'm certain). This could drain your battery, particularly if the battery is older and doesn't hold as much of a charge as it did when new.
    If you have a newer battery or a deep-cycle battery (such as an Optima yellow-top), this probably woudln't be an issue.
    How about the Wiki?
  1. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  2. Newbie in dc power supplier for car pc
    By 10007261 in forum Newbie
    Last Post: 03-09-2005, 02:30 PM
  3. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 01:42 PM
  4. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
