Results 1 to 10 of 10
Thread: Power Surge :-S
    Aug 2006
    Power Surge :-S
    i hope this is the right place to post this. :-)
    my car pc powers up and works fine ( with the engine off ) as soon as i turn the engine on then try turn the pc on it dont work ?? i have to disconnect the power lead and reconnect it to get the pc working again.
    what could the problem be ?? could the power wire not be the right power for the pc
    Newbie krustydawg's Avatar
    Apr 2005
    Need alittle more info.
    MB=
    Power supply=
    wire gauge=
    and where you are getting your power from?
    krusty
    Carputer Project: 95% Complete!!
    VIA EPIA MII 10000 motherboard | Morex Cubid 3688 Mini-ITX Case | 80Gb 2.5" Seagate Hard Drive | Kingston 512Mb PC2100 DDR Ram | Mini-PS2 USB Keyboard | Microsoft Windows XP SP2 | Lilliput 7" Touchscreen | Rikaline 6010
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    my guess is you are using an inverter..right? if so the inverter stops inverting power when you crank the engine as the voltage drops below a certain level (it can reach 8 volts) so you need to disconnect it and reconnect it.. there is nothin you can do about it but to go to DC-DC or get a better inverter..
    all that is if you are using an inverter
    Aug 2006
    Bit more info
    I have the car Pc linked to my 2nd battery. and my 2nd battery linked to my 1st battery with 4awg wire.
    its M10000 mother board that uses ATX power supply Built-in 12V DC-DC converter
    ( i have no idea of the AWG of the carpc power wire its thin )
    i belive its a power surge or lose of some sort as it works fine when the engine is off :'(
    Aug 2006
    :'( it still dont work when engine on
    Apr 2006
    Greece
    do u know what the built in DC-DC converter is? what type? check your battery voltage when your car is running..
    Aug 2006
    Thank's for the help but digital-car.co.uk Helped me fix it :-)
    For any one that has the same problem
    Quote Originally Posted by LinITX.com
    ok, the problem that you are having could be because the 12V DC-DC psu in the C156 does not regulate the 12V input from the battery. It just pushes it straight through to the mainboard.
    When the car is running the voltage from the battery is likely to be nearer 14V and you could damage your mainboard and drives by feeding them too high a voltage.
    To use the C156 in your car, you really need a regulator such as the Carnetix CNX-P1260 or CNX-P1290.
    Apr 2006
    Greece
    can you tell us what was it so other people with the same problem can help their self!
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Thanks for posting the info here too Rob.
    Tidder
    Try RevFE
    Aug 2006
    :-) im here to help the world :-)
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Power supply Problem
    By xGROMx in forum Power Supplies
    Last Post: 03-16-2007, 02:19 PM
  3. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
