Page 2 of 20 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 200
Thread: Startup / Shutdown Controller w/ LCD Char Screen
  1. #11
    Low Bitrate LUWE SYGABU's Avatar
    Jan 2006
    Nebraska
    New Schematic And Parts List
    Hey, You guys are very supportive thanx. I have recieved a lot of questions recently. I hope I can answer all of them for you guys.
    A fellow member, Opticzero, offered to work up a schem and I think he did a great job. It has a unique look, but most importantly it gets the point across. I'm sorry you guys haven't been able to read my hand written one very well. Also, he worked up a parts list as well. I hope these help.
    As for building them for sale. I was recently working on a PCB for this thing, but it's been put on the back burner for a bit. I'm moving to Omaha next week and as a single father with a 4 yr old 100% of the time, I have been busy. I will get the thing finished and I'll let you know if I'll be able to make some for you guys who aren't able to build one. It's really not that hard though. I'll let you all know soon.
    Thanks again for all of your support.
    Luwe
    Attached Files Attached Files
    May all your dreams come true.....unless your dreams are nightmares ~ L.S.
    http://www.mp3car.com/vbulletin/show-off-your-project/67759-2006-honda-civic-breaking-ground-what-warranty.html
  2. #12
    Jan 2006
    Nebraska
    For those of you who are having a hard time compiling the progam, this is the compiler IDE i used.
    http://www.microengineeringlabs.com/...es/win_ide.htm
    I will try to post a HEX file for you guys. I do find it much more adventageous for you so that you can use any PIC chip you want and can personalize the code for yourselves. I'll have to round up the HEX file.
    http://www.mp3car.com/vbulletin/showthread.php?t=67759
  3. #13
    Newbie optczr's Avatar
    Oct 2005
    I have tried to compile your code and noticed that there were some errors that showed. The following lines during the compile process were displayed. You have stated that you had some errors in your code and I just want to make sure that the ones listed below are them or did I do something wrong. Also posting the HEX file would be GREAT..
    The following lines can up as (BAD EXPRESSION)
    lcdout $FE, $C0+4, DEC2 SHTDWN_TIME, " Sec."
    lcdout $FE, $C0+4, DEC2 LOAD_TIME, " Sec."
    lcdout $FE, $C0+4, DEC2 IGNDLY_TIME, " Sec."
    Lcdout $fe, 1, Dec (temperature / 100), ".", DEC2 temperature, " C"
    Lcdout $fe, $C0, Dec (temperature / 100), ".", DEC2 temperature, " ", 223, "F"
    LCDOUT $FE, $C0, "-", DEC TEMPERATURE, ".", DEC2 TEMPERATURE, " ", 223, "F"
    The following lines can up as (SYNTAX ERROR)
    OWOut DQ, 1, [$55, $28,$B1,$FE,$22,$00,$00,$00,$5D,$44] ' Start temperature conversion
    OWIn DQ, 4, [count_remain] ' Check for still busy converting
    OWOut DQ, 1, [$55, $28,$B1,$FE,$22,$00,$00,$00,$5D,$44] ' Read the temperature
    OWIn DQ, 0, [temperature.LowByte, temperature.HighByte, count_remain, count_per_c]
  4. #14
    Oct 2005
    Forgot to add in the technical information.
    The compiler, which I am using, is PicBasic Pro with MicroCode Studio as the editor. The chip, which Iím trying to compile for is the PIC16F877A.
  5. #15
    Oct 2005
    Thanks for your Hex file. I'm downloading it right now. Your code will allow me to test the circuit, which I built from the drawings. Once I have everything working, Iíll let you know.
  6. #16
    Nov 2006
    Shut down issue with laptop. Consider going stand by mode
    Have switch to inverter shut down w ignition switch. (Simple low volltage relay) Have laptop screen closed when installed in car. Set power options for laptop to go to standby mode when screen is closed. When laptop goes from ac power to battery power it will go to standby mode. When you start car up and inverter comes on laptop will boot back up automatically. Thanks, Richard
    Should work but you know how Winblows is. Sometimes it takes some tweaking to get windows to operate properly.
  7. #17
    Jan 2006
    Nebraska
    FYI, you need to activate setup and set your startup and shutdown times using the menu and select buttons, prior to turning the ingintion. It is designed to be able to run setup without acc on. It will save your selections into the eeprom and they remain there until you either change the setting or reprogram the chip.
  8. #18
    Jan 2006
    Nebraska
    Quote Originally Posted by iceking69 View Post
    I think that having a laptop mounted on your dash is certainly an option, not desirable by most. It is much less space consuming not to mention self gratifying to have a touch screen mounted in the dash. Sometimes more difficult = more fun. Even if you are not intending to mount the laptop on the dash, some aren't using a laptop in their system. Good idea for a simple laptop power control though.
  9. #19
    Oct 2005
    I have attached a revised drawing, which shows a some changes from the original.
    1. R2 was changed from 1K to a 10K resistor.
    2 The PIC16F877A, VDD line is listed as +5 and the VSS is now listed as GND.
    Also wanted to say thanks to Luwe for his help.
  10. #20
    Oct 2005
    In the process of making a board and if everything goes good, I'll get my screen tomorrow and install this into my car Saturday (after testing)
  1. WTB DSSC Shutdown startup controller
    By xs10x in forum Classified Archive
    Last Post: 04-26-2006, 05:23 AM
  2. LCD screen size for double din opening...???
    By EclipseGSturbo in forum Newbie
    Last Post: 01-30-2006, 12:24 PM
  3. FS: 10.4 lcd screen with controller ect.
    By nmiller35 in forum Classified Archive
    Last Post: 07-15-2004, 11:35 PM
  4. 8.4" Sharp screen + earth lcd controller
    By cruzc_99 in forum Classified Archive
    Last Post: 07-01-2002, 06:56 PM
  5. latop lcd screen with controller card?
    By schrodos in forum General Hardware Discussion
    Last Post: 11-20-2000, 10:34 AM
