Page 4 of 20 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 200
Thread: Startup / Shutdown Controller w/ LCD Char Screen
  1. #31
    Newbie optczr's Avatar
    Oct 2005
    I've finished the board and everything fits correctly. Its a one layer board that requires you to solder components on both sides of the board, which means you need to have a little bit of soldering skills, but you don't have to be an expert. However I am having a few problems which I'm working out, but I'm almost there. Once I have the issue resolved, I will post the PC Board drawing. The last thing I want, is to provide a board which doesn't operate correctly.
  2. #32
    Oct 2005
    The layout requires a few jumpers, but its only a few. You can also see that you can still trim the board a little more to make it just a little smaller.
  3. #33
    Oct 2005
    I designed the LCD pinouts from the PIC to be a straight connection to almost every 16X2 LCD display. This means if you put pins on your 16X2 display, you can take a computer ribbon cable (IDE or floppy) and make the connection.
  4. #34
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    Just found this thread and have not read it all. I like the idee of the char LCD. I found the video very nice too. (why can't kids tell when you are busy!!??) I will probably steel some of your idee's LUWE.
    Even if I might reuse the IKE char display that came with my car accessible thru IBus... Dono.
    Good work and posting!
  5. #35
    Low Bitrate LUWE SYGABU's Avatar
    Jan 2006
    Nebraska
    HAHA, I wondered if anyone heard my little girl banging on the car door. That was sooo funny.
    OP - the select button is attached to the D2 pin, circuit it the same way all the other buttons are. Sorry about that oversight. And your board looks fantastic BTW, very good work! Don't forget to put a heatsink on your main power 7805 voltage regulator. And for the LCD power transistor, attache the base pin to the D6 pin, the collector to the +5v, and the other pin to the + PWR pin on the LCD. I would bench test it on a breadboard first , it should work theoretically.
    May all your dreams come true.....unless your dreams are nightmares ~ L.S.
    http://www.mp3car.com/vbulletin/show-off-your-project/67759-2006-honda-civic-breaking-ground-what-warranty.html
  6. #36
    Oct 2005
    Thanks Luwe:
    I will implement the add-ons and test the board. I hope to be done this evening and have everything posted...
  7. #37
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    Ok i am really new to this... i have no idea were to begin, if you can point me into a direction or something of that sort to get me started...
    also what parts u used and what not?
    Thanks Alot!
  8. #38
    Variable Bitrate pcfreak's Avatar
    Dec 2005
    Freeport, IL.
    Quote Originally Posted by optczr View Post
    Thanks Luwe:
    Any progress on this?
    Peese
  9. #39
    Variable Bitrate quantum's Avatar
    Sep 2005
    Ohhh, this is sweeet!
    Is it possible to buy one of these puppies? I have two left thumbs when it comes to soldering.
    PM is fine. TY!
  10. #40
    Oct 2005
    Smile
    Hi everyone:
    I'm about 95% complete on the new board layout, so just be patient a bit longer. I'm designing the board to make it as easy as possible and as small as possible so that anyone can put this together..
  1. WTB DSSC Shutdown startup controller
    By xs10x in forum Classified Archive
    Last Post: 04-26-2006, 06:23 AM
  2. LCD screen size for double din opening...???
    By EclipseGSturbo in forum Newbie
    Last Post: 01-30-2006, 01:24 PM
  3. FS: 10.4 lcd screen with controller ect.
    By nmiller35 in forum Classified Archive
    Last Post: 07-16-2004, 12:35 AM
  4. 8.4" Sharp screen + earth lcd controller
    By cruzc_99 in forum Classified Archive
    Last Post: 07-01-2002, 07:56 PM
  5. latop lcd screen with controller card?
    By schrodos in forum General Hardware Discussion
    Last Post: 11-20-2000, 11:34 AM
