Grrr.....OK, I may not know an awful lot about computer components but I'm pretty sure my M1-ATX
power supply has arrived faulty... I don't seem to get ANY power out of it!
Having set it all p ready to work I clearly wasn't getting anything to the motherboard so I've set up the following to test it.
Could you please have a look and let me know if I'm doing anything wrong because if not I'll have to contact my supplier.
1) Connect the faston power supplies and check voltage. + is getting 12v and sw is getting 12v...relative to the - terminal which is grounded.
2) Hacked up an old atx connector and grounded pin14 (PS_ON) connection. Same principal as DarquePerverts FAQ to powering a DC-DC PSU from indoors
here
I also bared the ends of one of the yellow wires (supposedly 12v) to allow for
testing later.
3) Put the jumpers in position A (although this shouldn't effect turning on I don't think)
4) Shorted J6 using spare jumpers (and J8 after just J6 didn't work) to mimic the motherboard switch being ON.
I then tested the voltage between the bared yellow wire and the green/black wire connection. Sweet F.A.
I also check the fuse on the board and its fine. Have I got a faulty board or am I being stupid?
