Results 1 to 9 of 9
Thread: need to stepdown 12v to 2.5/3v for wireless controller
    Constant Bitrate mikevsgeek's Avatar
    Jul 2004
    Auburn Maine
    I am using a wireless xbox control to transmit my steering wheel controls to my jeepPC seeing as how my clockspring doesn't have the wires needed.
    the wireless controller I am using uses 2 AAA batteries should be providing about 3v worth of juice, but its working on 2.3v right now so 2.5-3v would be perfect..
    the horn has a 12v line which I can tap into, but i am having a tough time finding a stepdown powersupply... actually I would like to just assembly one myself.. needs to be relatively small/flat, like maybe the size of business card or so...
    can anyone help me out with an electical design or maybe point me to in the right direction to existing schematics?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by mikevsgeek View Post
    How many amps?
    There are several Voltage Regulators that you can use to accomplish what you need. It isn't hard at all, and will be very small.
    I like the LM338K. It is not cutting edge stuff, but it will work. This is an adjustable voltage regulator, so you can set it where you want/need it, and is capable of supplying 3 amps of power when adequately cooled. If you require much less amperage, then you should have no heat issue with it.
    Michael
    Jul 2004
    Auburn Maine
    Quote Originally Posted by Wiredwrx View Post
    How many amps?
    Michael
    i cant imagine that a wireless control would need that many amps.. the controller doesnt list any amperage.. do you need to know amps in order to figure out what resistors are needed to build the right circuit?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    No, I wouldn't think it needs anyewhere near 3 amps, but I hate speculating about specs of devices. I only wanted to know so that the device can supply sufficient amperage. The resisters with a 338 only set the voltage, not the amperage.
    The more "robust" the regulator, the less worry about heat and drawing too many amps.
    Michael
    Sep 2006
    Budapest, Hungary
    Hi!
    I think you need a switching step-down converter.
    You can find some here: http://www.national.com/VCatalog/vie...gement&tId=206
    The LM2576-adj is your man. Its 3 amps output current and the output voltage range is 1.23V to 37V.
    http://www.national.com/pf/LM/LM2576.html#datasheet
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Like I said, there are many ways to accomplish this.
    I would just add that in the OP situation, any type of "switching" is a bad idea. Switching devices oscilate, causing an RF field that can effect wireless communications. It can rduce the effective range of a wireless device significantly. While this can be overcome, it will take some work and additional parts which are not needed with an LM338.
    Just keep that in mind.
    Michael
    Oct 2004
    NY
    yeah, a regulator like wired mentioned, or even a fixed 3v regulator would get the job done... I'd imagine the load is going to be a few hundred miliamps, & even then not continuous, a regulator with a small cap on the input & output would do fine...
    also, if your using an atx power supply for your pc, you already have a 3.3v feed that can be used from that with no add'l components..
    Jul 2006
    Plano, TX
    You can use LD1117-25 fixed 2.5v regulator at 1 ampare....if you need more amps, you can use LD1084-25 also fixed 2.5v at 5 ampares.
    LD1117 needs 5 volt input but, ld1084 will work from upto 30volts input...
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Don't make thing complicated.
    Get one of those cigarette adapter that has selectable voltage. Normally those are good for about 850mA and cost about 15 bucks or less.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Please HELP!! PSU/ Shutdown controller questions
    By RJP350Z in forum Power Supplies
    Last Post: 12-23-2004, 03:37 PM
  2. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  3. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  4. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 01:33 PM
  5. 12v on allens lcd controller....
    By MikeHunt79 in forum LCD/Display
    Last Post: 06-12-2002, 02:01 PM
