Results 1 to 3 of 3
Thread: help with powering a sub
    Sep 2006
    okay now this may sound stupid but me and my friend have this chair with speakers in it but it's a piece of **** so we put an 12" l5 solo baric in the back wit han alpine 300 watt amp it's not much but it's in the back of a chair comeon and the only trouble i'm having is powering it could i use a dc power supply or i've heard of a computer power supply would work too and where to find a small cheap reciever with a pre amp out so we just get bass instead of the sub playing all of the sounds
    Constant Bitrate Homebrew's Avatar
    The trick here is finding a power supply that can supply the necessary amperage to power the amplifier. Now if you have a high amperage amplifier, then a computer power supply won't cut it, you'll likely need an expensive bench power supply . The other option is to keep the gains on the amplifier down so it draws less. A lower amp fuse would also be a good idea to avoid overloading the power supply. Then you could use a computer power supply. Again first thing is first, you need to find out how many amps(max) your amplifier draws. To get a rough Idea, you could check the fuse for your amplifier. If your power supply can supply that amount of amps, then you're good to go.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    edit: woops read that wrong. you want to power that amp from inside off 110v, right?
    New System in progress:
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Powering a hard disk
    By oo00oo in forum Power Supplies
    Last Post: 05-31-2006, 07:57 AM
  2. Powering 7" touchscreen without SDC
    By ironic in forum Power Supplies
    Last Post: 12-16-2005, 08:24 AM
  3. Help powering 12" lcd
    By mattdisaster in forum Power Supplies
    Last Post: 09-28-2005, 04:32 PM
  4. Advice on Powering my System
    By st_claire in forum Power Supplies
    Last Post: 08-15-2005, 03:15 PM
  5. A solution for powering 12v stuff inside
    By zootjeff in forum Power Supplies
    Last Post: 12-17-2004, 07:21 PM
