well i bought the opus 250w right when it came out, and noticed that off the bat the atx cable didnt look like it was meant to go there:
http://webpages.charter.net/awkurlej/CarPC/atx.jpg
well last night I wired everything up and the cpu fan spins but nothing would post.
here is what I am trying to run on it, it should be able to handle it:
mAtx motherboard w/ onboard video with 3200+
1gb ram
250gb hd
wireless nic
gps (bu353, wasnt plugged in at the time)
7" lilliput (turned on, no input signal, tried home monitor as well, same thing)
I emailed opus to see what they say about the cable, and maybe theyll send me the right cable if that is the wrong one.
On a side note, I have a fused distribution block that I bought a long time ago and decided I should incorporate it in the system.
Well I wired everything and since I didnt have the correct fuses (anl style) I bridged the connections with a piece of wire for testing. When power was applied to it it made an awful high pitched squeal until the power was removed from it (bad ground? i don't think so since everything else worked).
