Results 1 to 10 of 16
Thread: opus 250w atx problem.
    Nov 2004
    well i bought the opus 250w right when it came out, and noticed that off the bat the atx cable didnt look like it was meant to go there:
    http://webpages.charter.net/awkurlej/CarPC/atx.jpg
    well last night I wired everything up and the cpu fan spins but nothing would post.
    here is what I am trying to run on it, it should be able to handle it:
    mAtx motherboard w/ onboard video with 3200+
    1gb ram
    250gb hd
    wireless nic
    gps (bu353, wasnt plugged in at the time)
    7" lilliput (turned on, no input signal, tried home monitor as well, same thing)
    I emailed opus to see what they say about the cable, and maybe theyll send me the right cable if that is the wrong one.
    On a side note, I have a fused distribution block that I bought a long time ago and decided I should incorporate it in the system.
    Well I wired everything and since I didnt have the correct fuses (anl style) I bridged the connections with a piece of wire for testing. When power was applied to it it made an awful high pitched squeal until the power was removed from it (bad ground? i don't think so since everything else worked).
    Elsewhere
    You appear to need a 24-pin ATX connector. It's the newer ATX standard. It appears that Opus makes the new 250w PSU with only the 20-pin connector.
    Here's a link to a 20-to-24 pin ATX adapter: http://www.saveateagle.com/wcab460-v...-V78&ovtac=CMP
    It's not the only one out there i'm certain. It should at least give you a jumping off point.
    How about the Wiki?
    Nov 2004
    i figured, im going to call opus and see if theyll send me the cable, i dont see the point in buying one if they didn't include the right one to begin with.
    Jun 2006
    St. Asaph, UK
    maybe you should have read the spec better?
    2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
    Nov 2004
    Quote Originally Posted by Ste_nova View Post
    I bought the psu in preperation. How is it my fault that the cables opus provides with the power supply aren't the right ones. I'd understand if they gave a 24pin to 24pin motherboard, but they included a 20pin all around and the actual power supply has a 24pin connector.
    Elsewhere
    I think what Ste_nova means is that if you'd read the specs and compared them to your motherboard, you'd know that you need the 20-pin to 24-pin adapter.
    I don't think Opus is going to supply you with the adapter you need or replace the unit with one that has the 24-pin connector. I could be wrong, since Opus is known to have top-notch customer service.
    How about the Wiki?
    Nov 2004
    Quote Originally Posted by DarquePervert View Post
    the motherboard is 20pin, i don't need an adapter for that. What I'm saying is that the cable that came with my opus powersupply is a 20pin (which is fine, connects right up to the motherboard) but the actual connector on the 250w opus is a 24pin, so I did not get the correct cable in the first place. How would I hook up a 20 pin cable to the 24pin connector on the powersupply without the correct cable.
    [opus 250w: 24pin] <==> (provided cable: 20pin, both ends) <==> [motherboard: 20pin]
    I don't see a reason for me having to spend more money on buying a cable to make the powersupply I purchased that already came with a cable but it did not fit into the actual powersupply.
    Thats like buying a DVI only monitor, and it coming with a standard vga cord.
    Sep 2006
    where did u buy the 250w opus?
    Maximum Bitrate DeltaFX's Avatar
    France
    DyeinBreed, an ATX 24 pin connector is only 4 pins bigger than a 20 atx, in the sens they are retro-compatible. Try to connect your 20-pins cable in the PSU atx connector (don't power it, who knows....), there should be only one way to do it.
    Now Galileo is real. Muhahahahaha :p
    Nov 2004
    directly from opus over the phone. I tried calling them but its too early as its only 830am there now.
  1. Fs: Opus Opus Opus 150w Atx Ps
    By arking in forum Classified Archive
    Last Post: 06-11-2006, 05:26 AM
  2. Does anybody use OPUS 120PSU with MB870? - Problem
    By mica in forum Power Supplies
    Last Post: 05-02-2006, 11:19 PM
  3. opus problem
    By eon in forum Power Supplies
    Last Post: 03-16-2006, 12:40 PM
  4. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 11:17 AM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 01:32 PM
