Results 1 to 3 of 3
Thread: So was my Opus overloaded?
    Emo is offline
    Nov 2005
    Orlando, FL
    Ok.. so I got my PC up and running.... every thing's fine... then I found a small 5 inch red light I bought a while ago.. well I thought it'd be perfect to stick it behind my center A/C vents.. and I did.. I must say.. it looked very cool at night..
    So this was during the day.. night time comes and I was gonna move my car.. turn it on and I wanted to take some night shots of it.. I went to my house.. got the camera and when I came back, the PC was off.. the lights still on and I smelled something burning...
    So I turned everything off... and tried to figure out where the smell came from.. wasn't the Motherboard area.. wasn't the new light.. but it was defiantly the power supply... I unplugged the new light and tried to turn on the pc.. the power was going up and down and it looked like the PSU was struggling to keep up. Then I thought.. let me unplug the LED fans I have.. and I was right.. the PC started up like normal...
    I connected the fans again and this time it worked fine.. so now everything is fine as long as I dont plug in that light again... (too bad)... but my question is.. what burned? the PSU/PC are still working fine..
    Also... how am I overloading this PSU? I have:
    EPIA 13000
    80GB Maxtor
    Fan cooler for the HDD
    2 LED system fans
    4 Port USB Hub
    1 WiFi PCI card
    and my Xenarc is also connected to the OPUS
    Soon when I get my IDE to USB cable I plan to hook up my slim load CDRW and eventually install my GPS receiver as well but seeing how it can't handle a little light, I'm starting to worry
    Here's how it looks now:
    any thoughts?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    opus 90 or 150.....or one of them new ones? that mofo will run how if not given the proper ventilation.......i'd say probably more of a cooling issue. I've heard of them melting the plastic off the stock wires
    PC Components:
    My work log
    Emo is offline
    Nov 2005
    Orlando, FL
    sorry, it's the OPUS 150
    The temps are fine.. at night the temps are:
    Mobo: 25-27C
    CPU: 35-38C
    HDD: 25-27C
    Here in Florida the temps during the day can get pretty up there.. today the hottest was:
    Mobo: 35C
    CPU 65C
    HDD: 30C
    That was when I first started up the car while it's been sittin in the sun for a few hours.. after a few minutes the temps go down about 10-15C
    the smell defenately was coming from the motherboard so I'm sure it wasn't any wires melting...
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. Opus 120 and MTSVO-SC, wiring questions
    By 01black_ac in forum Power Supplies
    Last Post: 03-22-2006, 08:36 PM
  4. I hate Car PCs!! Opus Problems!!
    By Anees in forum Power Supplies
    Last Post: 12-01-2005, 09:26 PM
  5. has anybody ever overloaded a opus 150W PSU?
    By CTdubbin in forum Power Supplies
    Last Post: 02-06-2004, 07:56 PM
