Results 11 to 20 of 21
Thread: 12 Volt Timer For Computer
  1. #11
    Apr 2001
    Portland OR
    Quote Originally Posted by kozmo View Post
    I searched and could not find anything so I am also going to assume this is the best place for this thread.
    Does anyone have or know of a 12 Volt Automotive Timer, like a kitchen timer but something I could put in my truck and it would allow me to leave the computer on after my truck is off for the desired amount of time set on the timer, so it could sync with my server at my house, etc.
    The uSDC20D basically does this exactly..
    Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  2. #12
    Aug 2004
    Hudsonville, Michigan
    Quote Originally Posted by zootjeff View Post
    Jeff
    No it does not it allows the user to turn off the computer early but does not allow me to set the timer for say 30 minutes shut off my truck go inside and know that in 30 minutes the computer will shut off. At least the way I understand it.
    Nate
    I know what yer thinkin...did he fire six shots or only five...
  3. #13
    Apr 2001
    Portland OR
    So you want it to normally shut down in a few secconds of turning off the car, but if you hit a button, it would turn off the car in 30 minutes that one time?
    The uSDC20D will turn off your computer. It pulls the plug on power, even if your computer crashes after it sends the shutdown pulse, it will be off.
    uSDC20D can be modified for the above situation.
    Can your battery power your computer for 30 minutes?
    -Jeff
    www.mpegbox.com
  4. #14
    Aug 2004
    -Jeff
    Yah my battery can do that.
    Nate
  5. #15
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Crouzet relay
    I use this Crouzet relay at work, it is a little complicated but can do what you need. This one has an analog dial to set the time. We set ours to shut down 10 minutes after we send a pulse.
    http://www.crouzet-usa.com/downloads...structions.pdf
  6. #16
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Update::
    http://store.mp3car.com/ProductDetai...Code=PWR%2D026
    This seems pretty good Im hoping it becomes available pretty soon so that I can test it.
    08 Lincoln Navigator www.mobiteklink.com
  7. #17
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    doing this in software would be the easy answer, only it would suck if for some reason the pc got 'stuck' shutting down
  8. #18
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I understand that a hardware based solution is likely what your looking for, but I use a simple registry tweak that allows you to select a shutdown time by right clicking on the "my computer" icon. I would think you could easily create a shortcut to make it a one click deal. I use this when I am updating or transferring files all the time. Handy when you know you wont be back for a while.
    save as a text document, and rename the extension to a .reg
    then run it and allow it to edit the registry.
    Code:
    Windows Registry Editor Version 5.00
    ;Right-click My Computer To Shutdown
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 10 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 10 Minutes\command]
    @="shutdown -s -f -t 600"
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 20 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 20 Minutes\command]
    @="shutdown -s -f -t 1200"
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 30 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 30 Minutes\command]
    @="shutdown -s -f -t 1800"
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 40 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 40 Minutes\command]
    @="shutdown -s -f -t 2400"
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 50 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 50 Minutes\command]
    @="shutdown -s -f -t 3000"
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 60 Minutes]
    [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Shutdown In 60 Minutes\command]
    @="shutdown -s -f -t 3600"
    2005 Ford Focus ST
  9. #19
    Dec 2003
    Portland, OR
    Quote Originally Posted by pate60 View Post
    not to say it cant happen, but I use it a LOT and have never seen it hang. It is basically the same thing as that old virus that would initiate a shutdown...worked good for it too Once initiated, it cannot be halted in any way I have found.
    2005 Ford Focus ST
  10. #20
    Jun 2004
    Wink
    Quote Originally Posted by gospeed.racer View Post
    actually it can be halted, the shutdown app has an '-a' switch to abort!
  1. Regulated 12 volt to 5 volt conversion - Howto?
    By psyclobe in forum Power Supplies
    Last Post: 04-21-2010, 05:24 PM
  2. 12 volt regulator
    By Kd7jmy in forum Power Supplies
    Last Post: 10-17-2005, 12:11 AM
  3. 12 volt DC-DC Converter
    By 4u2n in forum Power Supplies
    Last Post: 11-15-2004, 03:13 AM
  4. 12 Volt 250W,ATX WITH P4 CONNECTOR
    By xtreamvette in forum Power Supplies
    Last Post: 03-10-2004, 12:29 AM
  5. Replies: 0
    Last Post: 01-12-2002, 04:38 PM
