Results 1 to 3 of 3
Thread: Need help on power on pulse
    May 2002
    Been working on this circuit with little success so far.
    My current circuit is mainly using a bunch of nand gates.
    Looking for ideas on a new circuit approach.
    I need a circuit that does the following.
    When the car turns on and power is on the accessory socket for 2-3 seconds, then a pulse is sent to a relay which will wake my notebook from suspend. I also need a pulse when the car turns off to put the notebook back in suspend. The pulse needs to be short enough so the relay doesn't close that long.
    Jothen
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    555
    Would a 555 chip work? also do you have a copy of your schematic? (both before and after you converted everything to nand gates)
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    May 2002
    I have tried using the 555 timer, but so far I have not been able to generate a pulse yet.
    Current circuit using nand gates.
    Jothen
