Results 1 to 7 of 7
Thread: Plug Connector to pass power thru case
    Mar 2005
    I would like a quick connection method so I can unplug my pc and take it inside. I have searched some and found spade connectors mentioned, but I am not a great fan of them. I would rather some sort of plug that is more secure. The back of a subwoofer for a set of computer speakers I have has a screw on plug that has 3 pins. Something like that would be perfect.
    The only thing I found anywhere near that at RS is A CB plug It has 4 pins which is fine, but I don't know if it is safe to pull that much power thru it. (I have a mobile sempron in a nforce4 s754 microatx).
    Constant Bitrate hanzacra's Avatar
    Mar 2004
    Washington, DC
    EPIA M10K, Lilliput 7", 512MB RAM, 40GB 2.5" HD, M1-ATX, RoadRunner, FreeDrive, BU-353 GPS, Sabrent TV Tuner
    Mar 2005
    Thanks, they did indeed have some nice products.
    this and this
    look perfect. The site is strange though can a regular person buy things there? There is no pricing and it seems like they want resellers only not individuals ordering one plug and one receptacle.
    Mar 2005
    Well for now I just used a molex connector that I soldered together for the plug. It isn't pretty and hangs out flopping around, but it will get the job done until I change it later.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I used a neutrik speakon connector for many years. Has up to 4 poles and can handle the current with no problem.
    Mar 2005
    BTW thank you I ordered such a connector and I should have it installed next week.
    Feb 2006
    Dallas
    This my setup using the "CB" connectors. Works great for removing and installing.
  1. Home made power plug for Lilliput?
    By 96TransAm in forum LCD/Display
    Last Post: 09-02-2006, 03:16 AM
  2. Carnetix Case Power Cable
    By nappyjim in forum Power Supplies
    Last Post: 06-06-2005, 05:47 PM
  3. Gathering Ideas . . . Disconnect plug for Opus power
    By J187 in forum General Hardware Discussion
    Last Post: 06-01-2005, 12:29 PM
  4. temp battery power to the lighter plug?
    By xtra in forum General Hardware Discussion
    Last Post: 11-17-2004, 07:08 PM
  5. Install coming up... but Power questions
    By technopsych in forum Power Supplies
    Last Post: 04-14-2004, 08:16 PM
