how is the condition of the battery?
check heat also!
Hi all,
I'm testing my carputer at first everything seems to work fine, I boot into windows, but then my HDD resets and my pc lockusup. It must have something to do with the voltages, 'cause I just tried an "normal" AT PSU and the HDD doesn't reset & pc keeps running. So I measured the voltages both my PSU and the AT psu
my psu +12.4 & +4.96
AT psu +12.2 & 5.15
what do you think is the problem is the 12V to high or the 5V to low? Can I affort it to just try to turn up the 5V the 12V will go up also......
please respond quick, I want to continue!!!!!!!!!
thanx
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
check heat also!
Was there a load on your PSU when you measured these voltages?
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
