Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: M1 ATX 90 watt. No power to fuse.
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by squelch View Post
    There are no signs of damage or bad solder.
    Wiredwrx, yep, I will have to get a multimeter and learn how to use it to go any further, the light is crude but simple.
    It seems that the power to the fuse has nothing electronic to stop supply, this is all taken care of after the fuse, it is all mechenical ie: bad wire, bad solder.
    I appreciate all the replies, thanks.
    All you really need is continuity. Just put it in that mode, and touch the probes to the points, and if you hear a beep, they are connected (or read very little resistance if there is no beep) and you are set.
    Michael
  2. #12
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    ...It seems that the power to the fuse has nothing electronic to stop supply, this is all taken care of after the fuse, it is all mechenical ie: bad wire, bad solder...
    That is correct. The ferrite bead just has a piece of wire looping through it. I does that twice between the J11 and the fuse. If you don't have continuity, then there must be a bad soder joint. Sometimes the only way to find that is with a real meter.
    ~Jimmy
  1. FS: PC Power and Cooling 12V DC-DC ATX Power Supply
    By Mad Jad in forum Classified Archive
    Last Post: 07-24-2006, 10:38 PM
  2. POWMAX Mini ATX power supply - Power on leads?
    By e30_droptop in forum Power Supplies
    Last Post: 10-18-2005, 08:50 PM
  3. More info on OPUS automotive ATX power supply
    By InvisiBill in forum Power Supplies
    Last Post: 08-16-2002, 02:19 PM
  4. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 02:56 PM
  5. 90 watt atx power supply or something like that
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 12-01-1999, 02:05 AM
