Results 1 to 3 of 3
Thread: M1-ATX defect current limit shutdown
    Dec 2004
    Sweden
    I think my PSU is dying. I've had the same carputer setup for 2 years and has always worked fine, but recently I started having reboot problems. Now I get reboots all the time. I have isolated the problem to the PSU. When I only attatch the VIA MII12000 it starts fine and never cut but if I add the laptop hdd I can run a few secs and then power is out. Current draw is about 1.8A with just the MB and about 2.2A with hdd. To count out the laptop hdd I tried a spare 3,5" hdd instead but then it wouldn't even start at all. You could see the CPU fan "jump" a little every two seconds when it tried to start. I've also noticed that even with just the MB connected it takes a few extra seconds to start and you can see the CPU fan jump a bit on the first try. I suspect the M1-ATXs current limit gone crazy. Is there something I could try before I get a replacement unit??
    Thanks in advance
    Dec 2004
    Sweden
    Problem update:
    If I disconnect the MB and hot wire pin 13-14 I can run a 3.5" hdd without problems for unlimited time. Every pin has the right voltage besides the -12V witch is -13.8V. How do I know if my EPIA board is causing all this? I have tried a desktop ATX PSU and MB works great with that.
    Ideas?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by Gredd View Post
    Problem update:
    Ideas?
    Your power supply has a problem call Ituner up they can help
  1. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  2. ATX Shutdown Controller
    By low4life1 in forum Newbie
    Last Post: 12-10-2004, 11:05 AM
  3. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 10:52 PM
  4. ATX shutdown controller kit / assembled for sale
    By Mastero in forum Classified Archive
    Last Post: 01-27-2004, 02:33 PM
  5. New Idea for an awesome atx shutdown
    By moahdib in forum Power Supplies
    Last Post: 07-03-2002, 12:42 PM
