Results 1 to 8 of 8
Thread: M2-ATX Amp remote turn on......
    Feb 2006
    Manchester UK
    Howdy, i have the above psu & i was wandering how exactly i connect the remote turn on for my amp as the psu has both live & earth pins but the amp has only the live. Cheers.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Judofanatic2005 View Post
    HUH?
    Your amp should have Hi Power Positive, and a Ground for power, and then have a remote turn on, that is connected to the accessory/switched power source wire of the car, or to the Stereos remote turn on wire.
    The M2 atx replaces the connection of the Remote Turn on Wire from the amp to the car. Instead, the amp remote turn on wire gets connected to the M2.
    Michael
    Constant Bitrate ZtH01's Avatar
    Jan 2006
    Mankato, MN
    Quote Originally Posted by Wiredwrx View Post
    HUH?
    Michael
    There's 2 pins on the amp turn on section of the M1 and M2's. That's what was confusing him.
    Judo. You should do a little seaching. This has been covered NUMEROUS times before.
    -ZtH01
    "It's my belief that my big balls should be held every night"
    Feb 2006
    Manchester UK
    Thx for the replies however i cannot use the head unit remote wire as i aint gunna be using one. Everything mp3, gps etc is running off my carpc.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Dude, you have to explain yourself completely. Tell us your setup, what you want to accomplsih, and what is happening. THe fact that you are not using a HU HAS NO BEARING ON HOW TO CONNECT THE M2 TO YOUR AMPS.
    Michael
    Feb 2005
    He is wondering how to use TWO wires off the M2 ATX amp turn on header and turning on an amp that has ONE turn on wire.
    Brent
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
    carPC
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Use the pin on the left
    I've been wondering the same thing now...
    Manual Excerpt (courtesy of mini-box.com):
    The Left Pin is the one further away from the ATX 20 pin connector.
    Original Manual
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Mar 2006
    Colorado, but Canadian!
    I thought that the thread created explained himself just fine. The M2 has a 2 pin header for remote turn on. One is earth, one is live. Most amps use a live remote turn on, meaning, when they get +12v they turn on. Therefor you only need to use the live wire on the M2. The ground/earth pin on the M2 remains unconnected. You only use one or the other. If for some odd reason your amp needs to have a remote turn on that grounds a little voltage, then use the earth pin from the M2.
    So just use 1. More than likely, just take the + pin, and run a wire to your amp. Done.
    1.9in x 2.9in -- 47mm x 73mm
  1. opus remote wire doesnt turn off amp
    By evilragu in forum Power Supplies
    Last Post: 08-17-2006, 04:44 AM
  2. 12V PSU lead to remote amp turn on?
    By temposs in forum General Hardware Discussion
    Last Post: 01-12-2006, 09:39 AM
  3. Replies: 2
    Last Post: 01-26-2002, 05:53 PM
  4. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
  5. amp turn on
    By jasmar in forum General Hardware Discussion
    Last Post: 07-21-2000, 09:51 AM
