Mine's hooked straight to the +12v on the car...it handles the ~+14.5v just fine.
i was wondering if anyone could help me on this one ...
I wonder what the best way is to provide the Lilliput with its 12v.
1) Directly from the car's battery or its power net.
Advantage : Less cabling to do in the car (computer will be in the trunk,
Lilliput obviously not.
Disadvantage : Power fluctuations on the power net?
2) Spliced into the 12v wire of a Molex connector of a M2-ATX.
Advantage : Power supply should be stabilized by the M2-ATX.
Need to cut a Molex anyway, need 5v line for the hub.
Disadvantage : Extra drain on the M2-ATX, isn't running the hub and
the lilliput on one and the same molex not to much drain?
Your advice ?
Sincerely,
Jurgen
It's fused, but yes...actually it's connected to the IGN +12v (switched power).
i did the molex thing, IMO you should do this way(the molex). this way you dont need relays
I don't use relays.
wait.. so you can connect that yellow wire with the fuse (+12v) with a 4g power wire straight to the battery and it'll work?
hmm.. i should try that too. right now, there's power coming thru but my monitor just beeps and doesn't open. seems like a ground/power problem to me.
Bear in mind that the Lilliput is designed to accept regulated 12v power.
While it may work just fine running off the unregulated power from your battery, it may also damage/destroy your Lilliput. If it does, I'm certain that warranty would not cover the damage.
Food for thought.
not sure if mine's a lilliput but the 12v power line is yellow and it does have a fuse holder with a fuse in it. would it be wise to have another fuse coming from the bigger gauge power wire or is that just dumb? (ie.. 2 fuses.. one i put on and one that came with it.)
