Results 11 to 20 of 24
Thread: M2-ATX shutdown question
  1. #11
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by enhanced08 View Post
    Alright, I unhooked the J8 wire from the motherboard and turned the key, the system did not boot. i turned the key off and hooked up the wire to the board, turned the key and 5sec later it booted up.
    The wires should be hooked up correctly to the header unless positive and negative matter, which as far as i know they shouldnt.
    I'll have to check the BIOS again but i'm pretty sure there are no power options.
    Positive and negative can matter.
    Do you have a button that you can connect to the MB instead of J8. Power the M2 (including the accessory wire), push the button, and see if you boot. Push the button again, and see what happens. All the M2 does is simulate a button press. You can check for continuity between the two wires of J8 when it goes to shut down (with out it connected to the MB, to confirm that it is sending the "shutdown" signal)
    Michael
  2. #12
    Low Bitrate enhanced08's Avatar
    Jun 2006
    McHenry MD
    ok, i switched the wire and it seems to have worked. The only other thing i'm having a problem with is the fact that when i turn the key it doesnt shutdown. it will wait the 45sec then "hardoff".
  3. #13
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Did you confirm that the M2 is sending the "shutdown" signal by checking for continuity when it starts to shutdown.
    Also, check Control panel, Power Options, Advanced, and choose what you want to happen when the button is pushed.
    Michael
  4. #14
    Jun 2006
    McHenry MD
    Quote Originally Posted by Wiredwrx View Post
    no. i do not have a DMM which has the continuity test with me.
    there are no options for the power button in Power Options.
  5. #15
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    What MB do you have? Sounds like it doesn't support ACPI, which could be a problem.
    Michael
  6. #16
    Jun 2006
    McHenry MD
    my board is a PC Chips M825G v9.2a
    EDIT: did a google search and came across a few sites who sell this board and the specs on those sites claim it has support for ACPI v1.0.
    Would it be possible to remove support for ACPI on the software/OS side? I'm using an "nLited" version of XP which has a number of things removed. Could this be part of the problem?
  7. #17
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    And check your BIOS settings, you must enable ACPI ior API, whatever they call it.
    Michael
  8. #18
    Jun 2006
    McHenry MD
    checked BIOS, found an option that said ACPI Aware O/S - Yes so it should be enabled.
    booted the system, turned key off and it remains on for 45sec before hardoff
  9. #19
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Is it enabled. DL your manual (http://www.pcchips.com.tw/PCCWeb/Pro...ilName=Manual), and read the BIOS settings, and set them up correctly. There is also "power management enabled/disabled" in the BIOS.
    Then, back to control panel.
    If that doesn't work, and you determine that the M2 is sending the signal, then it is the MBs lack of ACPI support, or the OS.
    Michael
  10. #20
    Jun 2006
    McHenry MD
    ok, well the bios is setup right and it still doesnt work, i'm thinkin its the fact that i used nLite on the OS, tomorrow i'll see if i can get another hard drive and try a fresh install on it. I'll also see if i can get ahold of a DMM to check if the M2 is sending the signal.
    thanks for the help!
  1. Engine Noise with M2 ATX
    By lucky1 in forum Power Supplies
    Last Post: 08-26-2010, 08:04 PM
  2. Another M2 ATX Problem
    By mattfl in forum Power Supplies
    Last Post: 02-23-2006, 04:47 PM
  3. question involving shutdown?
    By ralphyboy1 in forum General MP3Car Discussion
    Last Post: 04-26-2005, 12:47 AM
  4. dumb question about regular atx power supplies.
    By acura cl in forum Power Supplies
    Last Post: 04-17-2005, 11:44 AM
  5. UPS / Auto shutdown question
    By gizmomkr in forum General Hardware Discussion
    Last Post: 05-22-2001, 02:33 AM
